Two phase incompressible immiscible fluid flow simulation |
Vivekananda
Rep Power: 9 ![]() |
Hello foamers,
I am trying to simulate the dispersed phase holdup by using twoPhaseEulerFoam which uses a two fluid model. Unfortunately I am unable to run the simulation beyond 6 secs. I am using bubbleColumn example by replacing air with oil. I have changed the physical properties and all that stuffs to that of oil phase. Later when I checked the twoPhaseEulerFoam.C file I found out that this solver is meant for two compressible phases one being dispersed in one another. Is there any provision to simulate two incompressible and immiscible liquids in contact in openFoam. Your guidance will be appreciated. Thanks in advance Vivek |
Two phase flow VOF ( fluid didn't fill the whole pipe) | M.Yosry | Fluent Multiphase | 1 | April 22, 2016 08:39 |
Miscible fluid flow simulation | j.patel | Main CFD Forum | 0 | November 6, 2014 04:54 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Algorithms for single phase flow equation of oil reservoir fluid | aadi.engr | Main CFD Forum | 0 | April 2, 2014 16:01 |
Newbie: advantages/disadvantages of "penalty formulation" incompressible fluid flow | bzz77 | Main CFD Forum | 2 | November 1, 2011 03:32 |
