Turbulence Model switch RKE to K-omega SST
Old   March 16, 2019, 09:54
Default Turbulence Model switch RKE to K-omega SST
Andrew
Astan is on a distinguished road
Hi guys, i would kindly ask some questions.
i'm dealing with a problem of external aerodynamics.
In the first try, i've used k omega sst, but it diverges because of the omega bc value.
In the second try, i've used RKE, i noticed it converges very rapidly.
I would like to understand 3 things:
1) is it normal (in general )that RKE converges faster than k-omega SST?
2) is k-omega SST stability more dependend from bc used with respect to RKE?
3) how could i switch from RKE model to K - omega SST for example after some iterations?
Thanks for the time spent to read this post.
Astan
Astan is offline   Reply With Quote
Old   March 29, 2019, 08:56
Andrew
hi guys, could anyone help me?
Old   March 31, 2019, 05:05
mzzmrt is on a distinguished road
I think convergence behaviour for RKE and kOmegaSST will be similar for an external aerdynamics problem.
If you can setup the case correctly according to the yPlus kOmegaSST can converge...
You can check this thread:
One more time: wall functions - SST
mzzmrt is offline   Reply With Quote
Old   April 6, 2019, 04:54
Andrew
thanks you for the reply mzzmrt, i found usefull that thread you suggest me!
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 03:47
Flow over a blunt body - SST turbulence model bharath CFX 5 January 29, 2016 11:16
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? JuPa CFX 0 December 22, 2015 07:44
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
k omega turbulence model sailspace OpenFOAM Running, Solving & CFD 0 November 12, 2013 06:43
