Long output in terminal.
Old   March 14, 2019, 07:03
Default Long output in terminal.
ssa
ssa_cfd is on a distinguished road
Hi all,
I am getting a very long output in the terminal, while the simulation is running. I want to get a normal reduced output. I tried to override a few Debugswitches using controlDict. But I could not change. Can anyone help.? (OpenFOAM v1706*+)
sample output from terminal for pitzdaily tutorial.
Create time
Overriding DebugSwitches according to controlDict
Create mesh for time = 0
Relaxation factors:
fields:
equations:
    U               0.9;
    ".*"            0.9;
SIMPLE: convergence criteria
    field p	 tolerance 0.01
    field U	 tolerance 0.001
    field "(k|epsilon|omega|f|v2)"	 tolerance 0.001
Reading field p
Reading field U
Lookup interpolationScheme for flux(U)
Setting fluxRequired for p
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
No finite volume options present
Starting time loop
Field relaxation factor for nu is unset
Field relaxation factor for k is unset
Field relaxation factor for nut is unset
Field relaxation factor for p is unset
Field relaxation factor for epsilon is unset
Field relaxation factor for U is unset
streamLine streamlines:
    Employing velocity field U
    automatic track length specified through number of sub cycles : 5
Time = 1
Lookup laplacianScheme for laplacian(nuEff,U)
Lookup fluxRequired for U
Lookup gradScheme for grad(U)
Cache: Calculating grad(U), originating from U event No. 14
Lookup divScheme for div((nuEff*dev2(T(grad(U)))))
Lookup divScheme for div(phi,U)
Find equation relaxation factor for U
Lookup equation relaxation factor for U
Lookup gradScheme for grad(p)
Cache: Calculating grad(p), originating from p event No. 12
Lookup solver for U
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0538101, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.030925, No Iterations 2
Lookup interpolationScheme for flux(HbyA)
Lookup snGradScheme for snGrad(p)
Lookup interpolationScheme for interpolate(((1|((1|(1|A(U)))-H(1)))-(1|A(U))))
Lookup laplacianScheme for laplacian((1|((1|(1|A(U)))-H(1))),p)
Lookup fluxRequired for p
Cache: Calculating grad(p), originating from p event No. 223
Lookup solver for p
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.068427, No Iterations 17
time step continuity errors : sum local = 1.19733, global = 0.179883, cumulative = 0.179883
Cache: Calculating grad(p), originating from p event No. 254
Cache: Calculating grad(U), originating from U event No. 284
Lookup laplacianScheme for laplacian(DepsilonEff,epsilon)
Lookup fluxRequired for epsilon
Lookup gradScheme for grad(epsilon)
Cache: Calculating grad(epsilon), originating from epsilon event No. 299
Lookup divScheme for div(phi,epsilon)
Lookup ddtScheme for ddt(epsilon)
Find equation relaxation factor for epsilon
Lookup equation relaxation factor for epsilon
Lookup solver for epsilon
smoothSolver:  Solving for epsilon, Initial residual = 0.199978, Final residual = 0.0100279, No Iterations 3
bounding epsilon, min: -1.98669 max: 1080.25 average: 47.5306
Lookup laplacianScheme for laplacian(DkEff,k)
Lookup fluxRequired for k
Lookup gradScheme for grad(k)
Cache: Calculating grad(k), originating from k event No. 43
Lookup divScheme for div(phi,k)
Lookup ddtScheme for ddt(k)
Find equation relaxation factor for k
Lookup equation relaxation factor for k
Lookup solver for k
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0439206, No Iterations 3
ExecutionTime = 0.34 s  ClockTime = 1 s
Time = 2
Lookup solver for U
smoothSolver:  Solving for Ux, Initial residual = 0.437825, Final residual = 0.030824, No Iterations 5
smoothSolver:  Solving for Uy, Initial residual = 0.283531, Final residual = 0.0258526, No Iterations 4
Cache: Calculating grad(p), originating from p event No. 600
Lookup solver for p
GAMG:  Solving for p, Initial residual = 0.052242, Final residual = 0.00424172, No Iterations 15
time step continuity errors : sum local = 4.02676, global = 0.102655, cumulative = 0.282538
Cache: Calculating grad(p), originating from p event No. 630
Cache: Calculating grad(U), originating from U event No. 660
Cache: Calculating grad(epsilon), originating from epsilon event No. 675
smoothSolver:  Solving for epsilon, Initial residual = 0.153295, Final residual = 0.0109463, No Iterations 3
bounding epsilon, min: -40.6096 max: 23853.2 average: 84.882
Cache: Calculating grad(k), originating from k event No. 431
Lookup solver for k
smoothSolver:  Solving for k, Initial residual = 0.419185, Final residual = 0.0313043, No Iterations 3
ExecutionTime = 0.37 s  ClockTime = 1 s
End
ssa_cfd is offline   Reply With Quote
Old   March 18, 2019, 06:25
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
What switches did you override?
alexeym is offline   Reply With Quote
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
[PyFoam] unknown or ambiguous terminal type x11 Tobi OpenFOAM Community Contributions 6 August 13, 2020 12:09
[swak4Foam] on run time object hchen OpenFOAM Community Contributions 6 December 4, 2014 16:39
Very long time for saving the output (sim) file ... Eike STAR-CCM+ 2 January 2, 2012 20:40
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP 4xF OpenFOAM Bugs 3 October 16, 2009 06:35
