Run OF case on SCC?
Old   March 13, 2019, 23:15
Question Run OF case on SCC?
LT
NewKid is on a distinguished road
Could anyone who accomplished OpenFOAM case on SCC (Super computation center) tell me how to give the command line if I try to run a case with 240 cores on 20 nodes?
I always get the message:Requested node configuration is not available.
Thanks in advance!
NewKid is offline   Reply With Quote
Old   March 21, 2019, 02:14
Question
LT
No any clues?
After I started to compute one OF case, the procedure halts while the messages were given as follows:
| \\ / O peration | Version: 4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.0
Exec : /WORK/app/OpenFOAM/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/bin/sprayFoam -parallel
Date : Mar 21 2019
Time : 13:58:51
Host : "cn9720"
PID : 2866
Case : /WORK/nsccgz_xliao_1/liutao/LMesh
nProcs : 240
Slaves :
239
...//something like 240 tasks are assigned
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0 // The procedure stops right here
PS: I can solve this case on one node.
case, command line, openfoam, scc
flotingObject case doesn't run when I change the dynamicMeshDict file. saatt OpenFOAM 1 July 9, 2017 09:26
How to run in transient the airFoil2D (simpleFoam) tutorial case? csacska OpenFOAM Running, Solving & CFD 5 June 19, 2017 09:45
damBreak case parallel run problem behzad-cfd OpenFOAM Running, Solving & CFD 5 August 2, 2015 18:18
Use XiFoam to run a laminar spherical flame case. fcrl-zxr OpenFOAM Running, Solving & CFD 0 June 8, 2015 12:11
DPMFoam case worked perfectly in the first run but crashes in every subsequent run!! ansubru OpenFOAM Running, Solving & CFD 6 March 17, 2014 05:27
