OF V1812 - new Atmospheric BC help..
Old   March 12, 2019, 06:00
Default OF V1812 - new Atmospheric BC help..
Andrew Wood
Solo Sails is on a distinguished road
Hi There,
I am a work it out as I go along foamer, so please go easy on me!
I have been trying to set up the simplest of cases
10m cube with all sides and floor as no slip walls and a zero gradient outlet using simpleFoam
but have been trying to set up the inlet using the new Improved atmospheric boundary layer conditions in V 1812 https://www.openfoam.com/releases/op...ary-conditions
Obviously I do have V1812 installed and running!
I am just copying and pasting the demo inlet conditions example from the link above, but just cannot run the case, it reads P and U then stops, no error, no anything.
There doesn't seem to be much information around about Atmospheric boundary inlets, and absolutely nothing on this new version, if anyone understands how to set it up and could point me in the right direction, I would be grateful.
Basically, I am trying to set up an external flow simulation with a graduated U speed and direction up the Z axis in order to simulate apparent wind (twist) over a moving object in real world atmospheric boundary layer
The domain needs to be at least 20m Z 20m x 60m Y
Thanks again!
Solo Sails is offline   Reply With Quote
Old   March 13, 2019, 00:12
clapointe is on a distinguished road
There is (nearly) always information in the corresponding .H file about how to use a boundary condition. You can find it in the source code. There is also a simpleFoam tutorial that uses it : https://develop.openfoam.com/Develop.../turbineSiting.
Caelan
clapointe is offline   Reply With Quote
Old   March 13, 2019, 03:50
Andrew Wood
Hi there, thanks for that, I didn’t know about the .h file or the tutorial! Thanks again.
atmospheric
outerCorrectorResidualControl OpenFOAM v1812 vs. OpenFOAM 6 Kobi_Faust OpenFOAM Running, Solving & CFD 5 February 28, 2019 08:51
outerCorrectorResidualControl OpenFOAM v1812 vs. OpenFOAM 6 Kobi_Faust OpenFOAM Running, Solving & CFD 0 February 27, 2019 05:30
How to generate a atmospheric boundary layer Morten Andersen CFX 3 January 16, 2007 07:48
both ends at atmospheric vid FLUENT 0 October 25, 2005 06:30
Atmospheric Turbulence:what about the time scales? Sebastien DELLA CROCE Main CFD Forum 1 September 1, 2000 13:03
