Mazen Draw
Rep Power: 7 ![]() |
Hello everyone!
Lately, I have been working on implementing Omega profile in the inlet BC of an ABL flow that I've seen in some paper. The idea is to define Omega based on k and epsilon. So one has to go from k-epsilon model to k-omega model. For modeling k in a previous k-epsilon case I used fixedProfile type in the inlet BC and imported data from csv.file and it worked without any errors. I want to do the same for omega, but I am getting the following exception: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-68e8507efb72 Exec : simpleFoam Date : Mar 10 2019 Time : 00:03:46 Host : "mazen" PID : 2281 I/O : uncollated Case : /home/mazen/ownCloud/MasterThesis_WtG_ValidationCase/Mazen/14.09/simulations/Mazen/CukOmegaS2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field Ux tolerance 1e-06 field Uy tolerance 1e-06 field Uz tolerance 1e-06 field "(k|epsilon|omega)" tolerance 1e-06 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmega --> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word '0.0001' file: IStringStream.sourceFile at line 0. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Code:
boundaryField { IN { type fixedProfile; profile csvFile;//[Yang 2009] profileCoeffs { nHeaderLine 0; refColumn 0; componentColumns (1); separator ","; mergeSeparators no; file "0/Omegaprofile.csv"; outOfBounds clamp; interpolationScheme linear; } direction (0 0 1); origin 0; } I wonder why I am getting this exception since the values in csv.file are of double scalar type which is what's needed. Anyone has an idea? Thanks in advance! |
Rep Power: 13 ![]() |
Looks like the scalar entry is being treated as a string given it's reading it as '0.0001' instead of 0.0001. Maybe you need to check your csv file. Try opening it in a text editor like gedit, notepad or vim. Are there quotations around the numbers?
#3 | |
Eren Kaya
Rep Power: 3 ![]() |
Hi MazenDraw, I wish you a good year.
I am working on an OpenFOAM CFD project for my graduation thesis. I want to implement k and epsilon values to specific locations using fixedProfile command and csvFile. My 0.k and 0.epsilon files are completely same with yours except the direction, which is (0 1 0) since it is in y-direction. After the iterations, when OpenFOAM begin to write the iteration results to timestep file, i.e. for my case 500, I am receiving an error message that is: --> FOAM FATAL ERROR: (openfoam-2206) unallocated autoPtr of type N4Foam9Function1INS_10SymmTensorIdEEEE From T* Foam::autoPtr<T>:: operator->() [with T = Foam::Function1<Foam::SymmTensor<double> >] in file /usr/src/packages/BUILD/src/OpenFOAM/lnInclude/autoPtrI.H at line 178. FOAM aborting I've searched the forum for this error but I could not find a solution. Can you give me any advice if you have encountered this error before? Thanks a lot. Quote:
Mazen Draw
Hello Eren,
This has been long time ago and I don't really have the files for this case anymore. If I remember correctly it is similar to your data, z coordinates in the first column and k values in the second. To give you something to work with, you can check out the boundary condition specifications of this tutorial https://github.com/OpenFOAM/OpenFOAM.../0/T.particles And here you can find the data file they used for it: https://github.com/OpenFOAM/OpenFOAM...allTemperature I know you are using a different version of OpenFOAM, but this boundary condition is so old that I can imagine it is almost identical in both versions. Finally pay attention to the entries: "nHeaderLin", "refColumn" and "componentColumns". They tell the solver where to start parsing the data from the data file. |
#5 | |
Eren Kaya
Thanks for your quick responding Mazen! Have a good day.
expected scalar, fixedprofile, inlet bc omega, omega profile |
How to implement kOmega turbulent model in to DPMFoam | amilachandra | OpenFOAM Programming & Development | 3 | October 22, 2018 22:48 |
fully developed channel flow with kOmega, wrong results | boshynova | OpenFOAM Programming & Development | 1 | April 20, 2016 10:54 |
SimpleFoam with Komega turbulence model? | tareqkh | OpenFOAM Post-Processing | 5 | December 11, 2014 16:38 |
Inheriting kOmega: why can't I change the constructor? | AlmostSurelyRob | OpenFOAM | 4 | October 27, 2011 04:34 |
Difference in velocity prediction by kepsilon and komega | Chander | CFX | 3 | September 19, 2011 19:11 |
