Preserving faceZone while using dynamic mesh refinement |
March 7, 2019, 05:08 |
Rep Power: 12 |
Hello everybody,
i would like to use the interFoam solver (OpenFOAM v1806) with dynamic mesh refinement and do some post processing on a faceZone. The problem is that the faceZone changes as the mesh is refined and can not be used for post processing any more. This happens even if the faceZone is already refined to the finest level, so that the mesh does not change in the area of the faceZone. I attached an image with a pre-refined faceZone at the beginning of a test case (grey) and after some iterations (red). Is there any way to preserve the faceZone with dynamic mesh refinement? Thanks in advance |
dynamicmesh, facezone |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Removing further cells after SHM | zonda | OpenFOAM Meshing & Mesh Conversion | 14 | September 15, 2017 07:50 |
[snappyHexMesh] Disturbance in the mesh after the addition of layers | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 0 | June 13, 2017 02:27 |
How to know mesh size after dynamic refinement | tayo | OpenFOAM | 16 | May 22, 2013 13:39 |
