March 7, 2019, 00:52 |
Which solver is correct?
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
Rep Power: 16 |
Hello friends,
I am using OF6 for my research project, aims of which to model Air(O2, N2, water vapor) interaction involving heat transfer, chemical kinetics, mass transport, and species transport. Simulation domain is gas Air(at different mole fraction) flowing from the bottom side (inlet) to top outlet reactions with porous media. Heat flux is provided from the right side of the domain Dimensions of the whole domain are 10mm x 3 mm x 1 mm. Schematics of the problem setup can be found in an attachment Any help/hints/advises will be appreciated, thanks in advance! |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
