Compiling new sixDoFRigidBodyMotion solver on HPC
Old   March 4, 2019, 03:01
Default Compiling new sixDoFRigidBodyMotion solver on HPC
Andreas
amh@inventas.no is on a distinguished road
Hello all,
I am working on an HPC with openfoam 6.0 and slurm and I am trying to compile a new solver.
1.) I copied the src folder for sixDofRigidBodyMotion to $HOME folder
2. I have created a new restraint (modified copy of linearDamper.C and .H) and added the same line to Make/files and also added last line of that file to $ (FOAM_USER_APPBIN). The files have been given a new folder with same name as files.
3.) I compile this, and the folder lnInclude is created, also containing the new externalForces.C and .H).
4.) When I try to use the new function in dynamicMeshDict and run interFoam I get following error: "Unknown sixDofRigidBodyMotionRestraint type externalForce". Indicating as I suspect one of two errors: failed compilation or missing sourcing or similar.
Could anyone out here help me with a good description of how to compile this and use it correctly? I am not very experienced with OF, so be gentle.
amh@inventas.no is offline   Reply With Quote
make: Clock skew detected. build may be incomplete. while compiling new solver. savee OpenFOAM Programming & Development 1 May 27, 2017 07:23
Hybrid discretisation - blend factor gcoopermax CFX 5 September 23, 2016 09:05
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Compiling meltFoam solver mick223 OpenFOAM Programming & Development 12 July 31, 2015 11:33
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
