March 3, 2019, 02:02 |
cyclicGgi BC for laplace motionSolver
Emad Tandis
Rep Power: 16 |
Hello All,
I'm trying to use cyclicGgi for solution of laminar flow in a pipe whose top wall is moving based on motionU (a tetPointVectorField type); and laplace motionSolver is used to solve mesh motion in domain. However, apparently, cyclicGgi was not defined for tetPointVectorField as a patchField in OpenFOAM ext. v4! Is there any suggestion? Thanks in advance |
March 3, 2019, 04:17 |
#2 | |
Emad Tandis
Rep Power: 16 |
I just solved the problem by setting fixedValue type in motionU for cyclicGgi patch and it got Ok. |
[snappyHexMesh] sHM and cyclicGgi | FabOr | OpenFOAM Meshing & Mesh Conversion | 28 | October 29, 2019 01:48 |
inlet pressure is higher than outlet pressure for fan | sivakumar | OpenFOAM Pre-Processing | 16 | December 30, 2017 15:16 |
How do I set up cyclicGgi boundaries in 1.6-ext? | olle | OpenFOAM Pre-Processing | 2 | October 7, 2014 13:59 |
cyclicGgi discontinuity problems | mbecker | OpenFOAM Running, Solving & CFD | 5 | February 27, 2011 12:36 |
For cyclicGgi boundary pressure is not solved ! | mahendra | OpenFOAM Running, Solving & CFD | 3 | March 16, 2010 05:05 |
