bashrc file and source bashrc position for cluster
Old   March 2, 2019, 07:46
Default bashrc file and source bashrc position for cluster
Andrew
Astan is on a distinguished road
Hi guys, I wanted to kindly ask for information.
I recently built a 2-node cluster, using nfs.
To use the cluster (with ubuntu) I had to insert the row
"source / opt / openfoam6 / etc / bashrc"
At the beginning of the ~ / .bashrc file and not at the end, (as written in the tutorial).
By doing this, after logging in, I get an error saying that some openfoam files have not been read correctly (but by doing this the simulation starts correctly).
If instead I follow the tutorial and insert "source / opt / openfoam6 / etc / bashrc"
at the end of the ./bashrc file, no error appears at login, but the simulation on the cluster does not start (an error appears).
How could I solve the problem?
Astan
Astan is offline   Reply With Quote
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 18:34
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
