Lagrangian solver selection
Old   February 28, 2019, 06:09
Default Lagrangian solver selection
rezaeimahdi's Avatar
mahdi
rezaeimahdi is on a distinguished road
Hello
I am interested in learning about DEM-CFD coupling modelling in OpenFOAM. However, when I read the solver descriptions, I got confused about how to select an appropriate solver for my simulation.
The simulation is about spraying water (like fog) in a simple box with only one inlet and one outlet and obviously, the fluid flow is turbulent(~ Re=10000). The discharge of the air and fog are given. The simulation temperature is equal to room temperature in this case.
The question is that, by these given data, how can I select a suitable solver?
Is there any document or tutorial that shows the procedure of modelling?
Please correct me if I am wrong also:
icoUncoupledKinematicParcelFoam is not a suitable solver for this simulation because the simulation is not passive transport. Is it correct?
But what about sprayFoam or DPMFoam? if I want to select DPMFoam, does volume fraction of particles effects on the continuous phase?
Thank you in advance
rezaeimahdi is offline   Reply With Quote
Old   June 12, 2020, 16:53
krishna kant
kk415 is on a distinguished road
Hello
I'm in the same situation and confusion like you @rezaeimahdi. SprayFoam is for compressible flow thus I think DPMFoam is more suitable for the above said case. Which solver did you used? How's the results?
kk415 is offline   Reply With Quote
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 04:10
Solver selection for transonic compressor stage in Foam-extend-3.0 dowlee OpenFOAM Running, Solving & CFD 1 April 16, 2015 14:33
Water droplets in gas with Lagrangian solver & SimpleFoam idnis OpenFOAM Programming & Development 1 July 8, 2014 02:54
Lagrangian Solver for N-S harish Main CFD Forum 1 May 12, 2005 09:43
