interIsoFoam Validation of Weir Flow
Old   February 22, 2019, 15:46
Default interIsoFoam Validation of Weir Flow
WaterHammer1985 is on a distinguished road
I'm trying to validate a weir coefficient using interIsoFoam but have run into an issue (see attached image). If I use the flow depth interface (alpha=0.5), the weir coefficient is much lower than anticipated. If I use the pressure to calculate the head, the weir coefficient is in the expected range. So I am unsure why the pressure matches what would be anticipated but the water surface depth does not.
Questions:
1. What would cause the pressure at the interface to be negative? There are ~7 mesh cells between 0Pa and the alpha interface so it isn't negative in just 1 cell (see the line plot in attached image)
2. Is there a way to have the interface correspond to 0Pa? If I change the alpha phase to 0.99 the interface is still negative.
0/U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    inlet_water
        type                      flowRateInletVelocity;
        volumetricFlowRate        constant 30;
        value                     uniform (0 0 0);
    outlet_air
        type            pressureInletOutletVelocity;
    outlet_water
    "(inlet_wall|conc)"
        type            noSlip;
    "(wall1|wall2)"
        type            symmetry;
    "(bed1|bed2)"
        type            noSlip;
    top
    defaultFaces
        type            empty;
0/alpha.water
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet_water
        type            fixedValue;
        value           uniform 1;
    outlet_air
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    outlet_water
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
    "(inlet_wall|conc)"
        type            zeroGradient;
    "(wall1|wall2)"
        type            symmetry;
    "(bed1|bed2)"
        type            zeroGradient;
    top
        type            inletOutlet;
        value           uniform 0;
    defaultFaces
        type            empty;
0/p_rgh
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform $pressure;
boundaryField
    inlet_water
        type            fixedFluxPressure;
    outlet_water
        type            totalPressure;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 4286970;
        value           uniform 4286970;
    outlet_air
        type            totalPressure;
        rho             rho;
        psi             none;
        gamma           1;
        p0              uniform 0;
        value           uniform 0;
    "(inlet_wall|conc)"
    "(wall1|wall2)"
        type            symmetry;
    "(bed1|bed2)"
     top
        type            totalPressure;
        p0              uniform 0;
    defaultFaces
        type            empty;
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    div(rhoPhi,U)  Gauss upwind; //Gauss limitedLinearV 1;
    div(phi,alpha)  Gauss upwind; //Gauss vanLeer;
    div(phirb,alpha) Gauss interfaceCompression;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
    div(phi,omega) Gauss upwind;
    div(phi,p_rgh)  Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
fvSolution
solvers
    "alpha.water.*"
        isoFaceTol      1e-6;
        surfCellTol     1e-6;
        nAlphaBounds    3;
        snapTol         1e-12;
        clip            true;
        nAlphaSubCycles 1;
        cAlpha          1; // Note: cAlpha is not used by isoAdvector but must
                           // be specified because interfacePropertes object
                           // reads it during construction.
    "pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-10;
        relTol          0;
    p_rgh
        solver          GAMG;
        smoother        DICGaussSeidel;
        tolerance       1e-07;
        relTol          0.05;
    p_rghFinal
        $p_rgh;
        tolerance       1e-07;
        relTol          0;
    "(U|k|omega|epsilon).*"
        solver          PBiCGStab;
        preconditioner  DILU;
        tolerance       1e-06;
        relTol          0;
    "(U|k|epsilon)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nCorrectors     3;
    nOuterCorrectors 1;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    fields
    equations
        ".*" 0.1;
WaterHammer1985 is offline   Reply With Quote
Old   February 27, 2019, 13:10
Default .
Additional information:
I'm using snappyHexMesh for the domain and mesh quality is good. The problem persists using interFoam and also doesn't appear to change based on fvSchemes order (1st vs 2nd). And none of the tutorial cases (weirOverflow, waterChannel, damBreak) have the same issue.
Any suggestions on where else to look to track this down would be greatly appreciated!
interface, interfoam, vof
Validation data for particle concentrations in a duct flow holgerbre Main CFD Forum 1 January 15, 2018 07:28
'2-phase' gas-liquid flow validation on this case. Ash Kot FLUENT 0 June 1, 2017 19:25
Validation for a channel flow code jinhua2015 Main CFD Forum 7 December 31, 2015 13:03
Boundary conditions for flow in nozzle kgevers FLUENT 0 July 26, 2015 13:46
URGENT! How do you find out the flow diversion % from a side weir? civilengineer FLOW-3D 0 March 20, 2014 08:45
