Floating point exception (core dumped) in OpenFOAM 6 |
February 21, 2019, 21:07 |
abdikerim kurbanaliev
Rep Power: 16 |
Dear All,
I solved case C from AIJ database in OpenFOAM 5. But, when I installed openFOAM 6, I have floating point exception (core dumped). Could you explain me what is going on. Cheers, Kerim |
February 22, 2019, 01:12 |
Rep Power: 16 |
Do I need any changes between OpenFoam 5 and OpenFoam 6?
February 22, 2019, 04:33 |
Rep Power: 16 |
At least, how can I remove openfoam6 from ubuntu 18.04?
February 22, 2019, 20:50 |
Rep Power: 16 |
Dear foamers,
thanks to wyldcrat (Quick answer: https://openfoamwiki.net/index.php/F...ve_OpenFOAM.3F) I solved my problem. Take care, Kerim |
February 24, 2019, 00:26 |
Rep Power: 16 |
Finally I solved my problem. SetDiscreteFields was reason of my problem with the AIJ caseC. Best, Kerim |
2-D airfoil simplefoam, Floating point exception (core dumped) | Hanseny | OpenFOAM Running, Solving & CFD | 0 | June 28, 2016 08:08 |
Floating point exception error (core dumped) | mechesanjiv | OpenFOAM Running, Solving & CFD | 2 | June 21, 2016 15:44 |
[waves2Foam] setWaveParameters application, it results in a floating point exception and the core | psahoo87 | OpenFOAM Community Contributions | 1 | February 4, 2015 12:42 |
simpleFoam Floating point error (Core Dumped) | sam.ho | OpenFOAM Running, Solving & CFD | 2 | December 31, 2013 06:57 |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 14:11 |
