February 20, 2019, 10:49 |
low-mach assumption of density-variable flow
Jianrui Zeng
Rep Power: 8 |
I am confused about the low-much assumption. I read some information about it in paper: The present study adopts the anelastic or low-Mach-number assumption with which the acoustic interactions and compressibility effects are eliminated from the full compressible Navier–Stokes equations. Without considering the compressibility effects, we can determine all thermodynamic state variables, such as density, enthalpy, etc., independently of the hydrodynamic pressure variations about a specified background or thermodynamic pressure, P0. It seems it is constant-pressure process, but I do not know how to deal with pressure in the code. It will update but what does constant-pressure mean? I am not sure if compressibility effects are eliminated, what influence will it have and what aspects of the equation should I modify? And I also confuse about the relation between psi and compressibility effects. I do not know how to modify psi under the condition of low-mach assumption. Any hint is highly appreciated. Regards, Calf.Z |
February 28, 2019, 09:36 |
Jianrui Zeng
Rep Power: 8 |
March 1, 2019, 09:10 |
Zander Meiring
Rep Power: 8 |
ignoring compressiblity effects implies a fluid is incompressible. This means that under pressure, a finite mass of fluid will not change volume (or compress) and therefore it's density remains constant. If you look at openFoam tutorials you will see a split between compressible and incompressible solvers.
March 1, 2019, 09:24 |
#4 | |
Jianrui Zeng
Rep Power: 8 |
However, the density of the fluid I research is strongly changed with temperature. So I think it is still a compressible problem. In some papers, it is said that if the equation adopt low-mach assumption, the p and rho should be decoupled. That means decoupling the variations in thermophysical quantities (density,diffusivity, viscosity) from pressure fluctuations. So I do not know how to modify the equation. Thank you. |
March 12, 2019, 05:12 |
Jianrui Zeng
Rep Power: 8 |
Based on some papers about low mach number solver, I have got some information:
rho and p should be uncoupled, that's to say rho should be affected by the variations of pressure. And pressure should be split into a thermodynamic pressure and a mechanical pressure, with the former holds constant and is used in the equation of state while the latter is allowed to vary through velocity changes in the flow and appears in the momentum transport equation. I am now using buoyantPimpleFoam but I do not know how to modify the code to meet the low mach assumption. The code: fvc::ddt(rho) + psi*correction(fvm::ddt(p_rgh)) should be modified I think. Any hint is highly appreciated. |
March 20, 2019, 10:06 |
#6 | |
Lukas Fischer
Rep Power: 8 |
Have you made any progress? I would be glad to hear from the final solution. I will share my thoughts on your post here. I guess you wanted to say "rho and p should be uncoupled, that's to say rho should NOT be affected by the variations of pressure." Do you agree? thermodynamic pressure: To uncouple p from rho you can use the incompressiblePerfectGas as the equation of state in constant/thermophyiscalProperties. This function is available in the heRhoThermo type. Use pRef as your reference pressure e.g. 1 bar in your mixture dictionary Code:
mixture { equationOfState { pRef 100000; } } In the rest of the code you should try to get rid of any pressure gradients affecting rho (e.g. in the EEqn). Moreover, if you have a low Mach number due to low velocity you should get rid of all terms with K (kinetic energy) because low velocity will lead to low kinetic energy. In createFields.H the static pressure is linked with the hydrostatic pressure Code:
// Force p_rgh to be consistent with p p_rgh = p - rho*gh; Since p_rgh = p - rho*gh you have to get rid of the terms thermo.rho() +-= psi*p_rgh (density update in pEqn) as this will make rho a function of your p again. The term fvc::ddt(rho) should be fine because rho is only a function of pRef, T and your gas value R in my opinion. What do you think about it? I would be glad to see your final solver here Quote:
March 20, 2019, 23:57 |
#7 | |
Jianrui Zeng
Rep Power: 8 |
For thermodynamic pressure, I have create a new library for tabular method which can read thermoproperties from tables, so I cannot use heRhoThermo type. The pressure in my tables is given only one value(constant), and the properties are changed with variable temperatures. But I don't know if this can meet the function of constant thermodynamic pressure. I think I should remove dp/dt terms in EEqn.H. But I don't know why the terms with K should be removed. Although it is low, should remaining it be more inaccurate than removing it? The term psi*correction(fvm::ddt(p_rgh)) is based on : rho=psi*p_rgh. If I don't modify it, there is still a relationship between rho and p, isn't it? I also think thermo.correctRho(psi*p - psip0) should be avoid. All in all, I think the update of rho shouldn't have any relationship with p. Any hint is highly appreciated. |
Vertical 2D, Variable density flow with hydrostatic pressure assumption | ehsansh89 | Main CFD Forum | 6 | May 24, 2014 14:09 |
Convective flux scheme for rather low Mach number flow | paulzhang | Main CFD Forum | 3 | December 12, 2012 18:06 |
variable density in single fluid simulation not running with total energy | viking | CFX | 2 | September 18, 2012 21:19 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 10:14 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
