BC for inlet angle for velocity
Old   February 19, 2019, 04:17
Default BC for inlet angle for velocity
BC
Tarun BC is on a distinguished road
Hi guys,
I'm facing a problem in fixing the boundary conditions to set up inlet angle for velocity. I'm using bouyantBousinesqiSimpleFoam as the solver.
I kindly request you to help me out on this.
Thank You
Tarun BC is offline   Reply With Quote
Old   February 20, 2019, 09:25
Zander Meiring
yambanshee is on a distinguished road
for a flow velocity of U and angle t, calculate: Ux = U*cos(t) and Uy = U*sin(t) and use those values in a fixedValue inlet velocity.
yambanshee is offline   Reply With Quote
Old   March 7, 2020, 20:14
Gang Wang
Gang Wang is on a distinguished road
Originally Posted by Tarun BC View Post
Hi guys,
Thank You
Hi!
Have you solved this problem? I also want to find a solution to define the inlet velocity direction with the inlet boundary. How to define it?
Best regards,
Gang Wang
Gang Wang is offline   Reply With Quote
Old   March 16, 2020, 20:46
Hesam Tofighian
H.Tofighian is on a distinguished road
You can use the line below to find the normal vector of any patch:
tmp<vectorField> n = patch().nf();
Be aware that the direction of this normal vector is outside the domain. So multiply it by the negative of magnitude of velocity in the updateCoeffs function of your new boundary condition.
If you don't like coding, use the flowRateInletVelocity Boundary condition.
H.Tofighian is offline   Reply With Quote
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 15:00
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 03:39
inaccurate contact angle capturing in high shear/viscousity flow chery1986 OpenFOAM Running, Solving & CFD 0 October 23, 2015 01:14
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 18:24
