Add some particles to OpenFOAM simulation and track their path
Old   February 19, 2019, 02:44
Default Add some particles to OpenFOAM simulation and track their path
methma Rajamuni
meth is on a distinguished road
Dear Foamers,
I want to add some particles to my flow past sphere simulations and track their path. So, I can have a clear picture of what happens in the wake behind the sphere. I have never done particle tracking before. I am using my own flow solver, and I want to add the particle tracking part to it. Can you please guide me? Which solver will be the most appropriate for my case?
It seems that I have to use a Lagrangian solver with a particle could. But, there are many lagrangian solvers, and I am confused about which one to use.
It's better if you can direct me with some simple tutorials.
Thank you.
Cheers!
Methma
meth is offline   Reply With Quote
Old   February 19, 2019, 07:30
Micke is on a distinguished road
as you have already seen, there are different particle solvers. The selection depends on the particle concentration in the flow.
Low concentration: 1-Way-Coupling sufficient (icoUncoupledKinematicParcelFoam). The velocity profile is frozen. Only the fluid has an effect on the particles.
If you have a higher concentration you can choose between MPPICFoam or DPMFoam. Depending on the setting, these solvers take Two-Way-Coupling(particle-flow interaction) or Four-Way-Coupling(particle-particle interaction) into account.
Start with IcoUncoupledkinematicParcelFoam. Should be fine in your case.
Micke is offline   Reply With Quote
Old   February 19, 2019, 08:39
Robert
RobertHB is on a distinguished road
Have you considered using paraviews streamline filter instead of adding particles for pathline tracking? To me it sounds like this would get you the results you are looking for.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
Is OpenFOAM appropriate for a river simulation jasonneuswanger OpenFOAM Running, Solving & CFD 8 December 18, 2020 05:25
Why my track file is 0 K after the simulation is saved calmdown911 STAR-CCM+ 0 December 19, 2017 11:22
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 09:51
Track path of phase using VOF Matiasi FLUENT 0 August 31, 2015 14:12
