Actuator disk source modelling error
Old   February 18, 2019, 17:56
Default Actuator disk source modelling error
Edward
EJohn is on a distinguished road
Hello everyone,
I am using an actuator disk with a 'cylinder annulus to cell' set.
My cylindrical channel has an inlet, outlet and no slip at the walls.
The simulation runs fine with this setup as I can see the pressure jump at the disk location.
When I add a shaft (also with no slip) inside the disk with a 'cylinder annulus', the simulation crashes with the following error:
Time = 0
mesh not changed.
Created cellSet actuationDisk1CellSet
Applying source cylinderAnnulusToCell
Adding cells with centre within cylinder annulus, with p1 = (1 0 0), p2 = (1.2 0 0) and outer radius = 1 and inner radius = 0.5
cellSet actuationDisk1CellSet now size 72131
Created cellZoneSet actuationDisk1
Applying source setToCellZone
Adding all cells from cellSet actuationDisk1CellSet ...
cellZoneSet actuationDisk1 now size 72131
End
--> FOAM FATAL IO ERROR:
file: unknown
FOAM exiting
Can someone please advice what's going wrong?
Thanks,
Edward
EJohn is offline   Reply With Quote
Old   February 22, 2019, 17:49
Edward
Hey all,
I am still trying to diagnose this issue but I can't seem to find a fix. I would really appreciate some responses.
Thanks,
Edward
Old   May 9, 2023, 00:21
Question
JiaRui lee is on a distinguished road
Originally Posted by EJohn View Post
Hey all,
Thanks,
Edward
Hello Ejohn. I am facing the same error.Have you already fixed the error. I will really appreciate you if you can provide any messages.Best wishes to you.
JiaRui lee is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
