February 15, 2019, 17:43 |
Mesh Changing When Importing from Fluent
Tom
Rep Power: 8 |
Hi everybody,
I am running into an issue with importing a mesh from Fluent into Openfoam where quadrilateral cells are getting changed into prisms instead of hex cells. I have attached three pictures that show the mesh in fluent, halfway through the process, and after I finish importing it to the correct format in OpenFOAM. Here is an overview of my process. This mesh is for a FSI code, so I need to have faceSet and corresponding faceZone on the edge of my '2D' mesh. 1. I make the mesh in Fluent and export it as a .msh file, in ASCII format. 2. I import the mesh with FluentMeshToFoam 3. I export the mesh with FoamMeshToFluent to preserve the mesh and get a third dimension. 4. I import the exported mesh with Fluent3DMeshToFoam Does anyone know why the fourth step would change my mesh from a nice Quad/hex dominant mesh to a mesh dominated by prisms? Is there anything I can do to post process this mesh and get it back to uniformly quad/hex? Thanks! |
fluent3dmeshtofoam, fluentmeshtofoam, mesh, openfoam |
[ICEM] error while importing mesh to FLUENT from ICEM | @nuj | ANSYS Meshing & Geometry | 0 | April 13, 2016 08:41 |
Trouble with importing intricate block-structured mesh from ICEM to Fluent | highhopes | FLUENT | 0 | February 22, 2015 15:02 |
surface mesh missing when importing to fluent | DineshramBalaji | FLUENT | 0 | January 30, 2015 02:19 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
A error about importing Gambit mesh to Fluent. | shin | FLUENT | 3 | November 19, 2002 03:09 |
