Flow not difusing into domain
Old   February 11, 2019, 16:35
Default Flow not difusing into domain
Negar Naghash
negarnaghash is on a distinguished road
Hi everyone,
I am trying to model a jet flow and I have tried 3D and now I am trying 2D simulation. The problem with the results I get from simulation is the flow does not spread into domain at all like there i a physical wall separating the jet flow from the rest of the domain. The case is turbulent and I am using kOmega model for it (although the laminar setting has the same problem) Also I am running the simulation using rhoCentralFoam solver.
velocity BCs:
inletOutlet for outlet
outletInlet for domain inlet
outletInlet for nozzle inlet
noSlip for nozzleWalls
outletInlet for farfield;
pressure BCs:
zeroGradient for outlet
fixedValue for domain inlet
totalPressure for nozzle inlet
zeroGradient for nozzleWalls
zeroGradient for farfield;
temperature BCs:
totalTemperature for nozzle inlet
Does anyone have any idea what can cause this?
I attached a screenshot of the flow here.
negarnaghash is offline   Reply With Quote
Old   February 15, 2019, 06:09
sufjanst is on a distinguished road
I guess your velocity 8 (and viscosity) is too high or you use the wrong turbulence model. What is your velocity? The flow in your pipe looks like you try to simulate a supersonic flow.
Your flowfield is exactly what I expect from k-omega with high velocities.
sufjanst is offline   Reply With Quote
Old   February 15, 2019, 16:50
Negar Naghash
The velocity is 170 but flow is subsonic with M=0.5 . The flow has a high Re roughly 6 e5. And honestly my understanding is the flow is behaving less viscous than what is supposed to.
How can I have any control on viscosity setups?
And what else may cause this problem I have here?
Old   February 15, 2019, 17:55
W. Schuyler Hinman
schuyler is on a distinguished road
I would make sure your viscosity is correctly set in your thermoPhysicalProperties file.
Also, for lower speed flows you should have very small residuals if you are using rhoCentralFoam. This is because it is density based. Try reducing them in your fvSolution file. For this flow speed, you could also try sonicFoam which is pressure based.
Are you providing any turbulence coming into the inlet? You could use turbulentIntensityKineticEnergyInlet for k, and turbulentMixingLengthFrequencyInlet for omega.
Finally, if none of those give you the results you expect, try to recreate an experiment or existing simulation from the literature. If it matches, then you know there is nothing wrong with your setup.
Schuyler
schuyler is offline   Reply With Quote
Old   February 16, 2019, 22:02
MF
mfrl is on a distinguished road
Please check the pressure field you computed.
My guess is that the static pressure in your external flow is getting lower and lower while the total conditions of the nozzle inlet are constant.
Mrfl
mfrl is offline   Reply With Quote
Old   June 3, 2019, 22:36
Bo Kong
huangfei is on a distinguished road
Hi, have you solved this problem? I face the same thing as you. It looks like existing unphysical pressure wave in the nozzle.
huangfei is offline   Reply With Quote
diffusion, komega sst model, rhocentralfoam, turbulence
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Modeling the flow domain in Icepak saisanthoshm88 Main CFD Forum 0 April 11, 2011 09:31
Domain for Pipe Flow Swarup FLUENT 0 September 29, 2005 00:25
