LPT: Code gets stuck after "Added 1 new parcels"
Old   February 11, 2019, 00:55
Smile LPT: Code gets stuck after "Added 1 new parcels"
godfatherBond's Avatar
Maximus Arelius
godfatherBond is on a distinguished road
Hello Everyone,
I am trying to run a spray combustion simulation using LES. After running for ~5000 time steps (w/ dt=1e-06) the code gets stuck at :
Solving 3-D cloud fuelCloud1
Cloud: fuelCloud1 injector: model1
Added 1 new parcels
The code gets stuck at this for hours. The mesh quality is Ok as may be seen from this,
Mesh stats
    faces:            3632893
    internal faces:   3611267
    cells:            1207360
    faces per cell:   6
    boundary patches: 4
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     1207360
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology                   Bounding box
    inletJet            473      496      ok (non-closed singly connected)   (-0.0022941398636 -0.0022941398636 0) (0.0022941398636 0.0022941398636 0)
    inletCoflow         3300     3344     ok (non-closed singly connected)   (-0.023 -0.023 0) (0.023 0.023 0)
    outlet              3773     3796     ok (non-closed singly connected)   (-0.046 -0.046 0.276) (0.046 0.046 0.276)
    side                14080    14124    ok (non-closed singly connected)   (-0.046 -0.046 0) (0.046 0.046 0.276)
Checking geometry...
    Overall domain bounding box (-0.046 -0.046 0) (0.046 0.046 0.276)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (-3.26238353783e-16 -9.91871009924e-17 1.64145405062e-16) OK.
    Max cell openness = 3.11034785118e-16 OK.
    Max aspect ratio = 11.3164429291 OK.
    Minimum face area = 1.90157343094e-08. Maximum face area = 1.15407802292e-05.  Face area magnitudes OK.
    Min volume = 1.64010708419e-11. Max volume = 9.93740928183e-09.  Total volume = 0.001362704.  Cell volumes OK.
    Mesh non-orthogonality Max: 42.553608524 average: 13.1870256687
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.48912315273 OK.
    Coupled point location match (average 0) OK.
    Face tets OK.
    Min/max edge length = 0.000143749999992 0.0083636363637 OK.
    All angles in faces OK.
    Face flatness (1 = flat, 0 = butterfly) : min = 0.999999904452  average = 0.999999997621
    All face flatness OK.
    Cell determinant (wellposedness) : minimum: 0.178877632945 average: 2.13438959315
    Cell determinant check OK.
    Concave cell check OK.
    Face interpolation weight : minimum: 0.24147048594 average: 0.496106306781
    Face interpolation weight check OK.
    Face volume ratio : minimum: 0.310136821802 average: 0.971367321108
    Face volume ratio check OK.
Mesh OK.
End
The injection model used is the patch injection with
    injectionModels
        model1
            type            patchInjection;
            patchName       inletJet;
            massTotal       0;
            parcelBasisType fixed;
            SOI              0.001;
            duration         50;
            parcelsPerSecond 1266683;
            nParticle        10;
            U0              (0 0 0);
            flowRateProfile constant 1;
            sizeDistribution
                type        general;
                generalDistribution
                    distribution
                        ( 3.8109384764E-06    0.0003484941 )
                        ( 4.61043807331E-06    0.00107342111298 )
                        ( 5.40993767023E-06    0.00461269121149 )
                        ( 6.20943726714E-06    0.00981273225724 )
                        ( 7.00893686406E-06    0.0169999950874 )
                        ( 7.80843646097E-06    0.0253469930221 )
                        ( 8.60793605788E-06    0.0355020732935 )
                        ( 9.4074356548E-06    0.0430382816585 )
                        ( 10.2069352517E-06    0.0456821381966 )
                        ( 11.0064348486E-06    0.0487437280437 )
                        ( 11.8059344455E-06    0.0494042002732 )
                        ( 12.6054340425E-06    0.0491658370365 )
                        ( 13.4049336394E-06    0.0502142074269 )
                        ( 14.2044332363E-06    0.0466755561253 )
                        ( 15.0039328332E-06    0.0451245975491 )
                        ( 15.8034324301E-06    0.0425333745328 )
                        ( 16.602932027E-06    0.0389389002971 )
                        ( 17.4024316239E-06    0.0352220209195 )
                        ( 18.2019312209E-06    0.0358097731086 )
                        ( 19.0014308178E-06    0.0347394717635 )
                        ( 19.8009304147E-06    0.0329766447077 )
                        ( 20.6004300116E-06    0.0317908224798 )
                        ( 21.3999296085E-06    0.0306212445313 )
                        ( 22.1994292054E-06    0.0294889789261 )
                        ( 22.9989288023E-06    0.026850356596 )
                        ( 23.7984283993E-06    0.0245094694289 )
                        ( 24.5979279962E-06    0.0229806679815 )
                        ( 25.3974275931E-06    0.0215792478899 )
                        ( 26.19692719E-06    0.0204036316226 )
                        ( 26.9964267869E-06    0.0194293421011 )
                        ( 27.7959263838E-06    0.0180227905273 )
                        ( 28.5954259807E-06    0.0163912595075 )
                        ( 29.3949255777E-06    0.0162337630891 )
                        ( 30.1944251746E-06    0.015486247662 )
                        ( 30.9939247715E-06    0.0150618921753 )
                        ( 31.7934243684E-06    0.0143649152225 )
                        ( 32.5929239653E-06    0.0133282181516 )
                        ( 33.3924235622E-06    0.0127343999081 )
                        ( 34.1919231591E-06    0.0120117516299 )
                        ( 34.9914227561E-06    0.0110242003253 )
                        ( 35.790922353E-06    0.0104723677058 )
                        ( 36.5904219499E-06    0.0101565101053 )
                        ( 37.3899215468E-06    0.0103536006335 )
                        ( 38.1894211437E-06    0.0100271944756 )
                        ( 38.9889207406E-06    0.00929628725347 )
                        ( 39.7884203375E-06    0.00820976837546 )
                        ( 40.5879199345E-06    0.00786692082195 )
                        ( 41.3874195314E-06    0.00690523193374 )
                        ( 42.1869191283E-06    0.00643648626995 )
                        ( 42.9864187252E-06    0.00641398206238 )
                        ( 43.7859183221E-06    0.00639147785481 )
                        ( 44.585417919E-06    0.00558366956976 )
                        ( 45.3849175159E-06    0.00490008428853 )
                        ( 46.1844171128E-06    0.00454244382159 )
                        ( 46.9839167098E-06    0.00427291014442 )
                        ( 47.7834163067E-06    0.00441059652012 )
                        ( 48.5829159036E-06    0.00370303351856 )
                        ( 49.3824155005E-06    0.00372816886233 )
                        ( 50.1819150974E-06    0.00377477657463 )
                        ( 50.9814146943E-06    0.00374524141185 )
                        ( 51.7809142912E-06    0.00338904631198 )
                        ( 52.5804138882E-06    0.00297919419234 )
                        ( 53.3799134851E-06    0.00261792278846 )
                        ( 54.179413082E-06    0.0025452450932 )
                        ( 54.9789126789E-06    0.00231808612267 )
                        ( 55.7784122758E-06    0.00206519300722 )
                        ( 56.5779118727E-06    0.00228040193365 )
                        ( 57.3774114696E-06    0.00237071620751 )
                        ( 58.1769110666E-06    0.00244165584872 )
                        ( 58.9764106635E-06    0.00220079526334 )
                        ( 59.7759102604E-06    0.00185840133667 )
                        ( 60.5754098573E-06    0.0016519385678 )
                        ( 61.3749094542E-06    0.00150762075531 )
                        ( 62.1744090511E-06    0.00141185904696 )
                        ( 62.973908648E-06    0.00158935457369 )
                        ( 63.773408245E-06    0.00165107561334 )
                        ( 64.5729078419E-06    0.00134556552197 )
                        ( 65.3724074388E-06    0.00125110050926 )
                        ( 66.1719070357E-06    0.00107725770879 )
                        ( 66.9714066326E-06    0.000905239157519 )
                        ( 67.7709062295E-06    0.00099533463522 )
                        ( 68.5704058264E-06    0.00108543011292 )
                        ( 69.3699054234E-06    0.000892307701056 )
                        ( 70.1694050203E-06    0.000808784323647 )
                        ( 70.9689046172E-06    0.000734195186446 )
                        ( 71.7684042141E-06    0.000674855843045 )
                        ( 72.567903811E-06    0.00061927141576 )
                        ( 73.3674034079E-06    0.000639932102095 )
                        ( 74.1669030048E-06    0.0006664632 )
                        ( 74.9664026018E-06    0.0006664632 )
                        ( 75.7659021987E-06    0.000616835891609 )
                        ( 76.5654017956E-06    0.00049877617314 )
                        ( 77.3649013925E-06    0.000399043111242 )
                        ( 78.1644009894E-06    0.000385142526712 )
                        ( 78.9639005863E-06    0.000371241942181 )
                        ( 79.7634001832E-06    0.000357341357651 )
                        ( 80.5628997802E-06    0.0003484941 )
                        ( 81.3623993771E-06    0.0003484941 )
                        ( 82.161898974E-06    0.0003484941 )
                        ( 82.9613985709E-06    0.0003484941 )
The mesh does not have a wall and the particles are set to escape the boundaries.
Please share your views on this problem.
Thanks
P.S: I am using OpenFOAM 5.x.
RS
🃏Maximus🃏
godfatherBond is offline   Reply With Quote
Old   February 11, 2019, 04:59
ssa
ssa_cfd is on a distinguished road
I had this problem in manual injection. I think it is unable to handle when there are more particles. Try to reduce the number of parcelspersecond. In my case it worked.!
ssa_cfd is offline   Reply With Quote
Old   February 11, 2019, 11:47
Thumbs up
Maximus Arelius
Thanks for replying! I will try it asap but I am using ~1.27 million parcels per second now as you may see in the file above, is it too large?
If somebody has other suggestions, please share.
Any help is highly appericiated!
Thanks
🃏Maximus🃏
lpt, openfoam 5.x, particle tracking, spray combustion, spray injection
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 11:07
State of the art in CFD technology Juan Carlos GARCIA SALAS Main CFD Forum 39 November 1, 1999 15:34
Use of an hydrodynamic model integrated in the vertical by the PHOENICS code Hafsia Zouhaier Main CFD Forum 2 March 15, 1999 09:23
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
What kind of Cmmercial CFD code you feel well? Lans Main CFD Forum 13 October 27, 1998 11:20
