kOmegaSSTLM : does anyone tried on other ERCOFTAC case studies
Old   February 8, 2019, 06:30
Default kOmegaSSTLM : does anyone tried on other ERCOFTAC case studies
Rémy CAVECCHIA
RemyCavecchia is on a distinguished road
Hi everybody,
I'm coming to you cause I'm stuck with kOmegaSSTLM transition model, I'm trying to validate it in different conditions for a research study on laminar/turbulent transition.
I've tried to use this model on the T3A tutorial which works quite well, I 've compared the results to the original paper of Langtry and Menter and plotted Cf/Re for the experimental data, the kOmegaSST and the kOmegaSSTLM.
The results seem quite good:
As we can see the kOmegaSST version is acting fully turbulent and the kOmegaSSTLM seems to find the good transition position for a turbulent viscosity ratio of 12 as described in the 2009 paper.
But when I change the BCs to simulate the T3B or T3A- conditions things are going bad. I've done the BCs calculation like a hundred times to be sure and doesn't seem to make any mistake.
Here the kOmegaSST is acting fully turbulent as expected but the kOmegaSSTLM seems to behave fully laminar like no transition occurs.
I've done a small correction in the case cause I found out, in the experiment details, that the flat plat as an angle of attack of 0.5degrees to avoid the detached flow at the leading edge which was not the case in the tutorial.
Thought it would solve the problem but even if the kOmegaSST behavior seems better there is nearly no change to the kOmegaSSTLM.
I give you below the details of my inlet BCs just to let you know. I didn't change any of the wall BCs from the tutorial.
I have checked all the source code of the model and didn't see any difference with the original one proposed by Langtry and Menter.
If someone as any idea this would help me!!
Thanks.
RemyCavecchia is offline   Reply With Quote
Old   February 9, 2019, 03:05
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by RemyCavecchia View Post
Hi everybody,
Thanks.
Hi Remy,
This thread looks interesting. How did you take the turbulent intensity into account?
What about the mesh resolution? Did you examine the sensitivity of the results to streamwise and wall-normal mesh resolution??
Syavash
Edit: I see in the table you provided that exact values of omega and k are calculated!
syavash is offline   Reply With Quote
Old   February 10, 2019, 16:23
Rémy CAVECCHIA
Originally Posted by syavash View Post
Hi Remy,
Syavash
Hi Syavash,
Thanks for your interest.
About the turbulence, as you noticed after, I took it into account calculating k, omega and Retheta.
About the mesh I allready tried finer meshes in both direction without any change, but it seems that I can find something close to a transition (but not at the good location) with a coarser mesh, i'm gooding deeper in this way and I'll let you know.
Old   February 11, 2019, 03:33
Ehsan Asgari
Hi Syavash,
Remy,
Thanks for sharing your findings. I will look forward to hearing more on this interesting subject.
Regards,
Syavash
Old   May 24, 2019, 00:45
Purn Prakash
purnp2 is on a distinguished road
Hello, Remy,
Can you share case files of all the three flat-plates? Did you create these cases by yourself?
I am working on a similar topic where I'll be using an EARSM model (with laminar-turbulent transition equations) for simulation.
Thanks.
purnp2 is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
ERCOFTAC T3A flat plate test case Cfdbug FLUENT 0 March 28, 2016 23:37
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) ArianeJasmin OpenFOAM Programming & Development 1 April 4, 2012 15:11
Error reading new case montag dp FLUENT 5 September 15, 2011 07:00
