k-omega SST RANS of a supersonic cavity using rhoCentralFoam
Old   February 4, 2019, 08:51
Default k-omega SST RANS of a supersonic cavity using rhoCentralFoam
madz
maddy11 is on a distinguished road
Hi all,
I'm simulating a supersonic cavity in rhoCentralFoam using SST k-omega model. My only problem is that the pressure fluctuations are slowly dying down. Why is this occuring? Anyone has a clue about this? Kindly reply asap.
maddy11 is offline   Reply With Quote
Old   February 7, 2019, 01:29
madz
If anyone knows about this problem, kindly help pls!!
Old   February 12, 2019, 02:09
Anjay
AlphaSierra is on a distinguished road
Hey Maddy,
Can you please elaborate on your issue? What BCs are you using and what are the initial conditions?
Anjay
AlphaSierra is offline   Reply With Quote
Old   February 13, 2019, 02:48
madz
Hi Anjay,
Thanks for your reply.
Inlet - initial velocity profile given and inlet pressure provided.
Walls - No slip and Zerogradient for pressure.
Outlet - Wavetransmissive for pressure and velocity.
Top - Wall
Initial conditions:
Inlet pressure = 39386.2 Pa
Mach 2.0 and Temperature = 166.66 K
y+ is 20.
Standard Wall functions are implemented in OpenFOaM.
Solver: rhoCentralFoam
Kindly let me know your mail ID. I can ping you if more details are needed.
Maddy.
Old   February 13, 2019, 03:47
Anjay
Hey,
Your initial values for k and omega are very important as well.
https://www.cfd-online.com/Wiki/Turb...ary_conditions
This link might help. The turbulence dissipation might be causing your problems.
Anjay
Urgent: Unsteady 3-D supersonic cavity flow Min-Sung Kang FLUENT 3 April 6, 2014 10:50
supersonic axisymmetric cavity flow jsinha1987 FLUENT 0 August 21, 2012 12:11
supersonic combustion cavity flameholder julurusandeep FLUENT 0 April 16, 2011 03:15
Supersonic Flow over a Cavity (coodles): Maximum Iterations Exceeded sushant OpenFOAM Running, Solving & CFD 0 April 9, 2009 03:52
Supersonic flow past cavity Aditya Main CFD Forum 3 November 18, 2005 11:49
