January 30, 2019, 06:43 |
Nasa Polynomials/ Janf for SES36
Henrik Johansson
Rep Power: 9 |
I am working for quite some time to simulate an axial turbine with SES36 as real gas. SES36 is alot like HFC-365mfc. I think there is something wrong with my Nasa Polynomials because the rothalpy is not correct. Im running foam-extend 4.0. Below are is my thermiphysicalProperties. Is this the correct way to calculate the nasa polynomials for a fluid? I have entropy, enthalpy and constant heat for a range of temperatures. I then use least square to fit these to the nasa polynomials. Code:
thermoType realGasHThermo<pureMixture<sutherlandTransport<realGasSpecieThermo<nasaHeatCapacityPolynomial<redlichKwong>>>>>; mixture SES36 1 184.53 28.5e5 450.7 2111670.0 -9762.24 -83.3023 0.845058 -0.00236983 3.14876e-06 -1.62616e-09 1.42087e-06 0.983296; Code:
// ************************************************************************************************************* // // Coefficient: [J/kmol*K] // SES36 --> Name // 1 --> number of Moles // 184.53 --> Molar mass, (Volume, old) [g/mol] // 28.5e5 --> critical pressure [Pa] // 450.7 --> critical temperatur [K] // 99263.04465 --> critical density (only for aungierRedlichKwong) [Molar Volume] = [Molar Mass] / [Critical Density] // 0.351 --> acentric factor (not needed for redlichKwong but for pengRobinson, aungierRedlichKwong and soaveRedlichKwong ) // 1329.5 --> constant cp of perfect gas (used for constantHeatCapacity) [J/K] // 49436.5054 --> 2.849677801e-13 --> 7 heat capacity polynomial coefficents --> NASA Heat Capacity Polynomial // 1.42087e-6 0.983296 --> two coefficents for sutherlandRealGasTransport, https://www.cfd-online.com/Forums/openfoam-pre-processing/62178-sutherlandtransport-setting-air.html Code:
import numpy as np from scipy.optimize import leastsq import matplotlib.pyplot as plt from tabulate import tabulate np.set_printoptions(threshold=np.nan) from SES36_Data import R, M, Import_Data, Get_Data_Names ''' *** INPUT *** ''' print("Avalibale SES36 data is:") names = Get_Data_Names() print(names) idx = int(input("Select data by number order, etc. 1,2,3...\r\nSelect: "))-1 print(names[idx] + " selected") T, Cp, s, h, Delta_Hf_298_15, h_298_15 = Import_Data(names[idx]) ''' Sutherland Transport, Calculate the two, (As, Ts), coefficients ''' mu1 = 15.8257e-6 # Pa*s or kg/m*s T1 = 126 # K @ 11.121bar mu2 = 14.2570e-6 # Pa*s or kg/m*s T2 = 102.62 # K @ 3,74bar ''' *** Calculation *** ''' ''' Sutherland Transport, Calculate the two coefficients ''' def Sutherland_Transport(mu1, T1, mu2, T2): ''' Sutherland Transport equation ''' ''' mu = As * T^(3/2) / (T + Ts) ''' rootT1 = np.sqrt(T1) mu1rootT2 = mu1*np.sqrt(T2) mu2rootT1 = mu2*rootT1 # Calculate TS: Ts = (mu2rootT1 - mu1rootT2)/(mu1rootT2/T1 - mu2rootT1/T2) # Calculate As: As = mu1*(1.0 + Ts/T1)/rootT1 return Ts, As def NASA_POLYNOM_PLOT_9(pars, T): a1, a2, a3, a4, a5, a6, a7, b1, b2 = pars y1 = a1/T**2 + a2/T + a3 + a4*T + a5*T**2 + a6*T**3 + a7*T**4 y2 = -a1/T + a2*np.log(T) + a3*T + a4*T**2/2 + a5*T**3/3 + a6*T**4/4 + a7*T**5/5 + b1 y3 = -a1/(T**2*2) - a2/T + a3*np.log(T) + a4*T + a5*T**2/2 + a6*T**3/3 + a7*T**4/4 + b2 return np.array([y1, y2, y3]) def NASA_POLYNOM_9(pars, T, Cp, h, s): a1, a2, a3, a4, a5, a6, a7, b1, b2 = pars F1 = a1/T**2 + a2/T + a3 + a4*T + a5*T**2 + a6*T**3 + a7*T**4 - Cp F2 = -a1/T + a2*np.log(T) + a3*T + a4*T**2/2 + a5*T**3/3 + a6*T**4/4 + a7*T**5/5 + b1 - h F3 = -a1/(T**2*2) - a2/T + a3*np.log(T) + a4*T + a5*T**2/2 + a6*T**3/3 + a7*T**4/4 + b2 - s return np.concatenate((F1, F2, F3)) def Round(var): form = '5g' if var.size > 1: for i in range(0,var.size): var[i] = format(var[i], form) else: var = format(var, form) return var ''' Solve the Sutherland Transport equation ''' Ts, As = Sutherland_Transport(mu1, T1, mu2, T2) print('\r\nSutherland Transport constants:\r\n\r\nAs = {0}\r\nTs = {1}\r\n'.format(Round(As),Round(Ts))) #print(As * T1**(3/2) / (T1 + Ts)) #print(As * T2**(3/2) / (T2 + Ts)) ''' Solve NASA Polynomials ''' # initial values par_init = np.zeros(9) h = Delta_Hf_298_15 + h - h_298_15 # H(T) = Delta Hf(298) + [ H(T) - H(298) ] best, cov, info, message, ier = leastsq(NASA_POLYNOM_9, par_init, args=(T, Cp/R, h/R, s/R), full_output=True) print('\n\r{0}\r\n'.format(message)) ''' *** Print Result *** ''' y_calc1, y_calc2, y_calc3 = NASA_POLYNOM_PLOT_9(best, T) * R best = Round(best) print(tabulate( [best], headers=['a1', 'a2', 'a3', 'a4', 'a5', 'a6', 'a7', 'b1', 'b2'])) print('\r\n{0} {1} {2} {3} {4} {5} {6}\r\n'.format(best[0], best[1], best[2], best[3], best[4], best[5], best[6])) fig, (ax1, ax2, ax3) = plt.subplots(1, 3, figsize=(12, 6), dpi=80, facecolor='w', edgecolor='k') fig.subplots_adjust(left=0.05, bottom=None, right=0.98, top=None, wspace=None, hspace=None) ax1.plot(T, Cp,'or', label = 'Input') ax1.plot(T, y_calc1, label = 'Leastsq') ax1.set_title('Cp') ax1.legend(loc=4) ax2.plot(T, h, 'or', label = 'Input') ax2.plot(T, y_calc2, label = 'Leastsq') ax2.set_title('h') ax2.legend(loc=4) ax3.plot(T, s, 'or', label = 'Input') ax3.plot(T, y_calc3, label = 'Leastsq') ax3.set_title('s') ax3.legend(loc=4) plt.show() Code:
import numpy as np # ----------------------------------------------------------------------------------- ''' *** 11.12 bar Isobar *** ''' # ----------------------------------------------------------------------------------- def Isobar11_12(select): if select == "data": T = np.arange(125, 230, 5) + 273.15 # K Cp = np.array([1.3293,1.3107,1.2943,1.283,1.2753,1.2702,1.267,1.2652, 1.2647,1.265,1.266,1.2676,1.2697,1.2723,1.2751,1.2782, 1.2815,1.285,1.2887,1.2925,1.2964 ]) * 1e-3 * M # J/kmol*K s = np.array([1.6568,1.67,1.6861,1.7018,1.7172,1.7323,1.7472,1.7619, 1.7764,1.7908,1.805,1.819,1.8329,1.8467,1.8604,1.874, 1.8874,1.9008,1.914,1.9272,1.9402 ]) * 1e-3 * M # J/kmol*K h = np.array([439.02,444.32,450.83,457.27,463.67,470.03,476.37,482.7, 489.03,495.35,501.68,508.01,514.35,520.71,527.08,533.46, 539.86,546.28,552.71,559.16,565.64 ]) *1e-3 * M # J/kmol Delta_Hf_298_15 = 96.48 *1e-3 * M # J/kmol <-- Heat of formation h_298_15 = 435.12 *1e-3 * M # J/kmol return T, Cp, s, h, Delta_Hf_298_15, h_298_15 elif select == "name": return "Isobar 11.12" else: print("Somthing went wrong with getting data/ name from" + Isobar11_12("name")) # ----------------------------------------------------------------------------------- ''' *** 10 bar Isobar *** ''' # ----------------------------------------------------------------------------------- def Isobar10(select): if select == "data": T = np.arange(120, 230, 5) + 273.15 # K Cp = np.array([1.286,1.2726,1.2615,1.254,1.2492,1.2464,1.2451,1.2449, 1.2456,1.2471,1.2491,1.2516,1.2544,1.2576,1.2611,1.2647, 1.2686,1.2726,1.2767,1.2809,1.2852,1.2896 ]) * 1e-3 * M # J/kmol*K s = np.array([1.6505,1.664,1.6798,1.6953,1.7105,1.7256,1.7404,1.755, 1.7694,1.7837,1.7979,1.8119,1.8258,1.8396,1.8533,1.8669, 1.8803,1.8937,1.9069,1.9201,1.9332,1.9462 ]) * 1e-3 * M # J/kmol*K h = np.array([435.11,440.47,446.8,453.09,459.35,465.59,471.81,478.04, 484.26,490.5,496.74,502.99,509.25,515.53,521.83,528.14, 534.48,540.83,547.2,553.6,560.01,566.45 ]) *1e-3 * M # J/kmol Delta_Hf_298_15 = 96.48 *1e-3 * M # J/kmol <-- Heat of formation h_298_15 = 435.12 *1e-3 * M # J/kmol return T, Cp, s, h, Delta_Hf_298_15, h_298_15 elif select == "name": return "Isobar10" else: print("Somthing went wrong with getting data/ name from" + Isobar10("name")) # ----------------------------------------------------------------------------------- ''' *** 5 bar Isobar *** ''' # ----------------------------------------------------------------------------------- def Isobar5(select): if select == "data": T = np.arange(90, 230, 5) + 273.15 # K Cp = np.array([1.1051, 1.1081, 1.1121, 1.1167, 1.1217, 1.1271, 1.1328, 1.1386, 1.1446, 1.1507, 1.1569, 1.1632, 1.1695, 1.1758, 1.1822, 1.1885, 1.1949, 1.2012, 1.2075, 1.2137, 1.2199, 1.2261, 1.2323, 1.2384, 1.2444, 1.2504, 1.2564, 1.2623]) * 1e-3 * M # J/kmol*K s = np.array([1.6115, 1.6257, 1.6407, 1.6555, 1.6702, 1.6848, 1.6993, 1.7136, 1.7279, 1.7420, 1.7561, 1.7700, 1.7839, 1.7977, 1.8114, 1.8250, 1.8385, 1.8519, 1.8653, 1.8786, 1.8918, 1.9049, 1.9180, 1.9310, 1.9439, 1.9567, 1.9695, 1.9822]) * 1e-3 * M # J/kmol*K h = np.array([410.95, 416.16, 421.71, 427.28, 432.88, 438.50, 444.15, 449.83, 455.54, 461.28, 467.05, 472.85, 478.68, 484.54, 490.44, 496.36, 502.32, 508.31, 514.33, 520.39, 526.47, 532.58, 538.73, 544.91, 551.11, 557.35, 563.62, 569.92]) *1e-3 * M # J/kmol Delta_Hf_298_15 = 111.57 *1e-3 * M # J/kmol <-- Heat of formation h_298_15 = 410.95 *1e-3 * M # J/kmol return T, Cp, s, h, Delta_Hf_298_15, h_298_15 elif select == "name": return "Isobar 5" else: print("Somthing went wrong with getting data/ name from" + Isobar5("name")) # ----------------------------------------------------------------------------------- ''' *** 1 bar Isobar *** ''' # ----------------------------------------------------------------------------------- def Isobar1(select): if select == "data": T = np.arange(40, 230, 5) + 273.15 # K Cp = np.array([0.9165, 0.9278, 0.9390, 0.9500, 0.9608, 0.9715, 0.9821, 0.9925, 1.0027, 1.0128, 1.0228, 1.0326, 1.0422, 1.0517, 1.0611, 1.0704, 1.0795, 1.0884, 1.0973, 1.1060, 1.1146, 1.1231, 1.1315, 1.1397, 1.1479, 1.1559, 1.1638, 1.1716, 1.1793, 1.1869, 1.1943, 1.2017, 1.2089, 1.2161, 1.2231, 1.2301, 1.2369, 1.2437]) * 1e-3 * M # J/kmol*K s = np.array([1.5559, 1.5706, 1.5851, 1.5996, 1.6141, 1.6285, 1.6428, 1.6571, 1.6713, 1.6855, 1.6996, 1.7136, 1.7276, 1.7416, 1.7554, 1.7693, 1.7830, 1.7967, 1.8103, 1.8239, 1.8374, 1.8509, 1.8643, 1.8776, 1.8909, 1.9041, 1.9173, 1.9304, 1.9435, 1.9564, 1.9694, 1.9822, 1.9950, 2.0078, 2.0205, 2.0331, 2.0457, 2.0582]) * 1e-3 * M # J/kmol*K h = np.array([370.03, 374.65, 379.31, 384.04, 388.81, 393.64, 398.53, 403.46, 408.45, 413.49, 418.58, 423.72, 428.90, 434.14, 439.42, 444.75, 450.13, 455.55, 461.01, 466.52, 472.07, 477.66, 483.30, 488.98, 494.70, 500.46, 506.26, 512.10, 517.97, 523.89, 529.84, 535.83, 541.86, 547.92, 554.02, 560.15, 566.32, 572.52]) *1e-3 * M # J/kmol Delta_Hf_298_15 = 129.41 *1e-3 * M # J/kmol <-- Heat of formation h_298_15 = 365.71 *1e-3 * M # J/kmol return T, Cp, s, h, Delta_Hf_298_15, h_298_15 elif select == "name": return "Isobar 1" else: print("Somthing went wrong with getting data/ name from" + Isobar1("name")) # ----------------------------------------------------------------------------------- ''' *** 0.1 bar Isobar *** ''' # ----------------------------------------------------------------------------------- def Isobar0_1(select): if select == "data": T = np.arange(-20, 230, 5) + 273.15 # K Cp = np.array([0.7498, 0.7635, 0.777, 0.7904, 0.8035, 0.8165, 0.8294, 0.842, 0.8545, 0.8668, 0.879, 0.891, 0.9028, 0.9144, 0.9259, 0.9372, 0.9484, 0.9594, 0.9703, 0.981, 0.9915, 1.0019, 1.0122, 1.0223, 1.0323, 1.0421, 1.0518, 1.0613, 1.0708, 1.08, 1.0892, 1.0982, 1.1071, 1.1159, 1.1245, 1.133, 1.1414, 1.1497, 1.1578, 1.1658, 1.1737, 1.1815, 1.1892, 1.1968, 1.2042, 1.2116, 1.2188, 1.2259, 1.2329, 1.2398]) * 1e-3 * M # J/kmol*K s = np.array([1.4887, 1.5035, 1.5183, 1.533, 1.5477, 1.5624, 1.5771, 1.5917, 1.6063, 1.6209, 1.6354, 1.6499, 1.6643, 1.6787, 1.693, 1.7074, 1.7216, 1.7358, 1.75, 1.7641, 1.7782, 1.7922, 1.8061, 1.82, 1.8339, 1.8477, 1.8615, 1.8752, 1.8888, 1.9024, 1.9159, 1.9294, 1.9428, 1.9562, 1.9695, 1.9828, 1.996, 2.0091, 2.0222, 2.0353, 2.0482, 2.0612, 2.074, 2.0868, 2.0996, 2.1123, 2.1249, 2.1375, 2.15, 2.1625]) * 1e-3 * M # J/kmol*K h = np.array([322.43, 326.21, 330.06, 333.98, 337.97, 342.02, 346.13, 350.31, 354.55, 358.86, 363.22, 367.65, 372.13, 376.67, 381.27, 385.93, 390.65, 395.42, 400.24, 405.12, 410.05, 415.03, 420.07, 425.15, 430.29, 435.48, 440.71, 445.99, 451.32, 456.7, 462.13, 467.59, 473.11, 478.66, 484.27, 489.91, 495.6, 501.32, 507.09, 512.9, 518.75, 524.64, 530.57, 536.53, 542.53, 548.57, 554.65, 560.76, 566.91, 573.09]) *1e-3 * M # J/kmol Delta_Hf_298_15 = 142.49 *1e-3 * M # J/kmol <-- Heat of formation h_298_15 = 321.16 *1e-3 * M # J/kmol return T, Cp, s, h, Delta_Hf_298_15, h_298_15 elif select == "name": return "Isobar 0.1" else: print("Somthing went wrong with getting data/ name from" + Isobar0_1("name")) # ----------------------------------------------------------------------------------- ''' *** Import Data *** ''' # ----------------------------------------------------------------------------------- def Import_Data(name): if name == Isobar11_12("name"): return Isobar11_12("data") elif name == Isobar10("name"): return Isobar10("data") elif name == Isobar5("name"): return Isobar5("data") elif name == Isobar1("name"): return Isobar1("data") elif name == Isobar0_1("name"): return Isobar0_1("data") else: print("\n\r Error! Name does not exist! Could not import data.\n\r") def Get_Data_Names(): return Isobar11_12("name"), Isobar10("name"), Isobar5("name"), Isobar1("name"), Isobar0_1("name") ''' *** Gas Properties *** ''' R = 8.314472e-3 # J/kmol*K M = 184.53 # kg/kmol
/ Henrik Johansson Last edited by HenrikJohansson; January 30, 2019 at 07:56. |
January 8, 2020, 05:21 |
#2 | |
Rep Power: 9 |
Because CoolProp gives different values. Using the example of the heat capacity for the 1 bar isobar: Your values: Code:
Cp = array([0.16941502, 0.17150383, 0.17357415, 0.1756075 , 0.17760388, 0.17958177, 0.18154119, 0.18346363, 0.18534909, 0.18721608, 0.18906458, 0.19087611, 0.19265067, 0.19440674, 0.19614433, 0.19786344, 0.19954557, 0.20119074, 0.20283591, 0.2044441 , 0.20603381, 0.20760503, 0.20915777, 0.21067354, 0.21218931, 0.21366811, 0.21512843, 0.21657026, 0.21799361, 0.21939847, 0.22076635, 0.22213424, 0.22346517, 0.22479608, 0.22609004, 0.22738399, 0.22864097, 0.22989795]) # J/kmol*K Code:
Cp = array([0.14436495, 0.14673565, 0.14921751, 0.15180839, 0.15450591, 0.15730744, 0.1602101 , 0.16321083, 0.16630641, 0.16949345, 0.17276842, 0.17612771, 0.17956763, 0.1830844 , 0.18667425, 0.19033333, 0.19405783, 0.19784394, 0.20168785, 0.20558583, 0.20953415, 0.21352918, 0.21756733, 0.22164509, 0.22575902, 0.22990578, 0.23408211, 0.23828485, 0.24251091, 0.24675733, 0.25102123, 0.25529983, 0.25959046, 0.26389054, 0.26819758, 0.27250922, 0.27682317, 0.28113724]) # J/kmol*K |
April 9, 2021, 04:10 |
Henrik Johansson
Rep Power: 9 |
Hi .bastian,
Thank you for the input. The data is from Solkane 9. Software supplied by the manufacturerer Solkatherm of SES36. The rothalpy problem as I now understand it is a problem from the Mixing Plane. I have started this old project again and will update here when I have found a solution or any other problem regarding the NASA Polynomials
/ Henrik Johansson |
eos, janf, nasa, polynomials, ses36 |
therm.dat NASA polynomials | mystix | OpenFOAM | 5 | May 31, 2018 04:17 |
NASA Polynomials >> UNITS << | Tobi | Main CFD Forum | 11 | February 23, 2017 14:47 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
nasa polynomials | gardian | CFX | 3 | March 10, 2011 07:29 |
NASA polynomials, thermo.dat tables | Tomislav Sencic | Main CFD Forum | 8 | December 15, 2009 11:09 |
