overInterDyMFoam crash in parallel - solution singularity |
January 30, 2019, 05:20 |
Thomas Sprich
Rep Power: 11 |
Dear Foamers,
I'm using OF1806 to model the rotation of two rotors offset from each other, each with two blades. This is a multiphase problem, so I am using overInterDyMFoam. I have been running on a single processor, but on changing to parallel processing I receive the following error on the first iteration step: Code:
Execution time for mesh.update() = 0.79 s smoothSolver: Solving for alpha.water, Initial residual = 1.353549218e-09, Final residual = 1.353549218e-09, No Iterations 0 Phase-1 volume fraction = 0.4181040843 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.4181104467 Min(alpha.water) = 0 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 2.322414915e-16, Final residual = 2.322414915e-16, No Iterations 0 Phase-1 volume fraction = 0.4181104467 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.4181104467 Min(alpha.water) = 0 Max(alpha.water) = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.83028911e-10, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 4.743562107e-11, No Iterations 2 DILUPBiCG: Solving for p_rgh, Initial residual = 0.9995489713, Final residual = 0.1032830896, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.05135346298, Final residual = 54033200.29, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.9945517149, Final residual = 0.2754961416, No Iterations 1000 DILUPBiCG: Solving for p_rgh: solution singularity time step continuity errors : sum local = 1.637118569e+23, global = -1.875729674e+21, cumulative = -1.875729674e+21 DILUPBiCG: Solving for p_rgh, Initial residual = 1, Final residual = 627.3066397, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.7921979107, Final residual = 0.1789164504, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.4782676038, Final residual = 3.608746382, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.8500953436, Final residual = 0.08637729416, No Iterations 1000 time step continuity errors : sum local = 9.608309622e+46, global = -2.32551894e+45, cumulative = -2.32551894e+45 DILUPBiCG: Solving for p_rgh, Initial residual = 1, Final residual = 149.1396146, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.9226201229, Final residual = 2.655674273e+10, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.9318445964, Final residual = 1.991960637, No Iterations 1000 DILUPBiCG: Solving for p_rgh, Initial residual = 0.960292077, Final residual = 23587.71697, No Iterations 1000 time step continuity errors : sum local = 1.426870104e+110, global = -1.815010396e+108, cumulative = -1.815010396e+108 [1] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&) at ??:? at ??:? [0] #1 Foam::sigFpe::sigHandler(int)[1] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? at ??:? [0] #2 ? in /lib64/libc.so.6 in /lib64/libc.so.6 [1] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)[0] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? at ??:? [1] #4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[0] #4 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? at ??:? [1] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[0] #5 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? at ??:? [1] #6 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&)[0] #6 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? at ??:? [0] #7 [1] #7 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) constFoam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [1] #8 Foam::SolverPerformance<double> Foam::dynamicOversetFvMesh::solve<double>(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [0] #8 Foam::SolverPerformance<double> Foam::dynamicOversetFvMesh::solve<double>(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [1] #9 Foam::dynamicOversetFvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [0] #9 Foam::dynamicOversetFvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [1] #10 at ??:? [0] #10 ?? at ??:? [0] #11 at ??:? [1] #11 __libc_start_main__libc_start_main in /lib64/libc.so.6 [1] # in /lib64/libc.so.6 12 [0] #12 ?? at ??:? [83743d5aaf09:01547] *** Process received signal *** [83743d5aaf09:01547] Signal: Floating point exception (8) [83743d5aaf09:01547] Signal code: (-6) [83743d5aaf09:01547] Failing at address: 0x3e80000060b [83743d5aaf09:01547] [ 0] at ??:? [83743d5aaf09:01546] *** Process received signal *** /lib64/libc.so.6(+0x35270)[0x7f2d42a16270] [83743d5aaf09:01547] [ 1] [83743d5aaf09:01546] Signal: Floating point exception (8) [83743d5aaf09:01546] Signal code: (-6) [83743d5aaf09:01546] Failing at address: 0x3e80000060a /lib64/libc.so.6(gsignal+0x37)[0x7f2d42a161f7] [83743d5aaf09:01547] [ 2] /lib64/libc.so.6(+0x35270)[0x7f2d42a16270] [83743d5aaf09:01547] [ 3] [83743d5aaf09:01546] [ 0] /lib64/libc.so.6(+0x35270)[0x7ffa10f9a270] [83743d5aaf09:01546] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7ffa10f9a1f7] [83743d5aaf09:01546] [ 2] /lib64/libc.so.6(+0x35270)[0x7ffa10f9a270] [83743d5aaf09:01546] [ 3] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x30)[0x7f2d43e48200] [83743d5aaf09:01547] [ 4] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x25)[0x7ffa123cc1f5] [83743d5aaf09:01546] [ 4] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_5FieldIdEERKS2_h+0xa3e)[0x7f2d43c9950e] [83743d5aaf09:01547] [ 5] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_5FieldIdEERKS2_h+0xa3e)[0x7ffa1221d50e] [83743d5aaf09:01546] [ 5] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x11e)[0x7f2d46dddade] [83743d5aaf09:01547] [ 6] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x11e)[0x7ffa15361ade] [83743d5aaf09:01546] [ 6] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x285)[0x7f2d4691f745] [83743d5aaf09:01547] [ 7] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0xf)[0x7f2d468e655f] [83743d5aaf09:01547] [ 8] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x285)[0x7ffa14ea3745] [83743d5aaf09:01546] [ 7] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/liboverset.so(_ZNK4Foam20dynamicOversetFvMesh5solveIdEENS_17SolverPerformanceIT_EERNS_8fvMatrixIS3_EERKNS_10dictionaryE+0x217)[0x7f2d4521ea37] [83743d5aaf09:01547] [ 9] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/liboverset.so(_ZNK4Foam20dynamicOversetFvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x9)[0x7f2d4521eda9] [83743d5aaf09:01547] [10] overInterDyMFoam[0x44793f] [83743d5aaf09:01547] [11] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f2d42a02c05] [83743d5aaf09:01547] [12] overInterDyMFoam[0x450ea2] [83743d5aaf09:01547] *** End of error message *** /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0xf)[0x7ffa14e6a55f] [83743d5aaf09:01546] [ 8] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/liboverset.so(_ZNK4Foam20dynamicOversetFvMesh5solveIdEENS_17SolverPerformanceIT_EERNS_8fvMatrixIS3_EERKNS_10dictionaryE+0x217)[0x7ffa137a2a37] [83743d5aaf09:01546] [ 9] /opt/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/liboverset.so(_ZNK4Foam20dynamicOversetFvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x9)[0x7ffa137a2da9] [83743d5aaf09:01546] [10] overInterDyMFoam[0x44793f] [83743d5aaf09:01546] [11] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7ffa10f86c05] [83743d5aaf09:01546] [12] overInterDyMFoam[0x450ea2] [83743d5aaf09:01546] *** End of error message *** Code:
Solving for p_rgh: solution singularity HTML Code:
https://www.cfd-online.com/Forums/openfoam-solving/59814-solution-singularity.html For my BCs, as I said this works on a single core. I had a pressureInletOutletBC on the top wall to simulate an open to atmosphere condition. This was based off the tutorials. I also tried changing this from pressureInletOutlet to a wall. I have no other inlets or outlets into the domain. While I say it runs one a single core, I haven't run it that long and it may still crash. I've attached my case, but I had to remove the mesh because it was too big. Does anyone have any more ideas on how to fix this or how to try and diagnose this further? Thanks, Thomas |
December 27, 2022, 00:27 |
Himanshu Banait
Try,
massFluxInterpolation false; in PIMPLE section |
codedFixedValue: accessing other patch causes crash in parallel | RL-S | OpenFOAM Running, Solving & CFD | 2 | December 24, 2019 21:20 |
Unsteady simulation solution files in parallel | gunnersnroses | SU2 | 1 | December 15, 2015 13:28 |
2D Flow through parallel planes solution behavior with respect to cell size. | maCrobo | OpenFOAM Running, Solving & CFD | 4 | August 27, 2015 05:39 |
reactingParcelFoam 2D crash in parallel, works fine in serial | FerdiFuchs | OpenFOAM Running, Solving & CFD | 5 | August 10, 2015 18:19 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
