Convergence Issues with LTSInterFoam
Old   January 28, 2019, 08:21
Default Convergence Issues with LTSInterFoam
Florian
Archoncomando is on a distinguished road
Good day to you!
I'm having some issues getting viable results from my OpenFOAM case.
I'm simulating a curved Hydrofoil wing that is partially submerged in water and going at a speed of 45km/h or 12.5m/s.
To get a readout on the forces i'm using the forces function in the control dict. However when my simulation gets to timestep 2000 it's already giving me forces in the range of 4*10^30N which couldn't possibly be correct.
Someone working on a similar project before me gave me his case files to work with and i think i adjusted all values that changed. He told me to lower the MaxCo number in case the case keeps diverging. So far going from 0.9 to 0.75 hasn't helped however.
Does anyone have a good idea what could be causing this or how i could find out what's the cause? I'm a bit lost at the moment.
If posting specific case files helps please let me know i don't want to spam this post with every file in the system, constant and 0 folders.
kind regards and thanks in advance!
Florian
Archoncomando is offline   Reply With Quote
convergence, hydrofoil, issue, ltsinterfoam, watch
partial slip b.c., convergence issues Saideep OpenFOAM Running, Solving & CFD 3 August 2, 2016 10:18
Convergence Issues with Poisson equation in Fractional Step Code FluidFox Main CFD Forum 5 July 13, 2016 09:01
Convergence issues with heat transfer from tube wall Gadders FLUENT 3 October 12, 2015 10:03
Convergence issues for low Y plus values in Fluent NicoCFD FLUENT 1 February 4, 2015 11:55
Convergence Stability Issues ts_swati Fluent Multiphase 0 July 7, 2014 22:11
