NACA 0012 Airfoil Simulation
Old   January 24, 2019, 04:24
Default NACA 0012 Airfoil Simulation
Gurpreet Singh
badwalgurpreet is on a distinguished road
Hello, Dear OpenFOAM Users,
I am trying to validate NACA 0012 airfoil simulation using OpenFOAM 5.0x using simpleFoam solver. I created a C-H type mesh using Pointwise meshing tool and successfully exported to OpenFOAM. My simulations inputs are as follow:
(1): Free Stream Velocity = 45 m/s
(2): Mach Number = 0.13
(3): Free Stream Pressure ( (101325 pa) and Temperature (300 k )
(4): Density of air = 1.225
(5): Kinematic Viscosity = 1.4607*10^-5
(6): Reynolds Number = 3.0807 *10^6
I run this case for Angle of Attack (A.O.A) = 10 degrees and I got the results for Lift and Drag Coefficients like
Cd = -0.00339582
Cl = 0.0797399
which seems incorrect.
Can someone help me how to get the right values of Cl and Cd ?
0.tar.gz
system.tar.gz
checkMesh.pdf
constant.tar.gz
0.tar.gz
system.tar.gz
checkMesh.pdf
constant.tar.gz
badwalgurpreet is offline   Reply With Quote
naca 0012, pointwise, simplefoam
airfoil mesh genaration and simulation with a trip on surface issue rajibroy Mesh Generation & Pre-Processing 1 December 3, 2014 03:04
Comparison the airfoil 0012 experimental result and simulation result harrislcy FLUENT 30 August 29, 2013 11:27
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
NACA 0012 Simulation in CFX Satheesh CFX 1 March 22, 2011 22:18
NACA 2412 airfoil simulation using Turbulence Models mahbub03 Main CFD Forum 0 February 1, 2011 13:48
