Error while solving turbulent combustion using rhoreactingfoam
Old   January 23, 2019, 08:58
Default Error while solving turbulent combustion using rhoreactingfoam
Nikhil Bollimuntha
Nikhil Bollimuntha is on a distinguished road
I have been receiving this error while trying to execute the case file for turbulent combustion using the rhoReactingFoam solver.
Here's the link to the case file:
https://drive.google.com/open?id=1gs...rXX_wkV1GdbGlu
Nikhil Bollimuntha is offline   Reply With Quote
Old   January 23, 2019, 17:10
clapointe is on a distinguished road
The output shows you have a problem computing nut (at the boundaries -- line that starts with "#3"). Check your nut boundary conditions.
Caelan
clapointe is offline   Reply With Quote
Old   January 24, 2019, 08:35
Nikhil Bollimuntha
Sir, were you able to have a look at the case files? Because, to the best of my knowledge the boundary conditions I have set are correct.
Old   January 24, 2019, 15:28
I tried to suggest an answer before downloading someone else's case. How about posting your nut text here? Have you compared it to other tutorials that use rans?
Caelan
Old   January 25, 2019, 10:12
Nikhil Bollimuntha
Here is the nut file sir:
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object nut;
dimensions [0 2 -1 0 0 0 0];
internalField uniform 0;
boundaryField
fuel-inlet
type calculated;
value uniform 0;
air-inlet
type calculated;
value uniform 0;
outlet
type calculated;
value uniform 0;
upperwall
type calculated;
value uniform 0;
lowerwall
type fixedValue;
value uniform 0;
frontandback
type empty;
And to answer your second question, yes sir, I have compared it and to most extent used values from the tutorial cases.
Old   January 25, 2019, 13:31
The error you posted indicated it was a problem with a wall function calculation. However, you are not using wall functions. Did you change it, or are you using wall functions elsewhere?
Caelan
Old   January 25, 2019, 23:27
Nikhil Bollimuntha
I have used the qRWallFunctionk in the k file and epsilonWallFunction in the epsilon file.
Old   January 26, 2019, 00:07
Not totally sure, but I'd hazard a guess that using those wall functions necessitates using a wall function for nut as well.
Caelan
Old   January 26, 2019, 06:18
Nikhil Bollimuntha
Just executed the same case by adding wall function to the nut file as well, same error.
Old   January 26, 2019, 19:46
Ok so we've erased one possibility. Given that the simulation immediately crashes, this suspects your initial conditions. Have you tried other values for k and epsilon? Where did you get your current ones?
Caelan
Old   January 26, 2019, 22:25
Nikhil Bollimuntha
So since you suggested the problem might be with the initial conditions and given that the error indicates that it is with the wall functions, I substituted the wall functions with constant values and now I'm getting another kind of error (attached below)
File Type: jpg Screenshot 2019-01-26 at 9.00.02 AM.jpg (82.2 KB, 9 views)
Old   January 26, 2019, 22:36
It's still a segfault -- looks like a division error. This is often due to division by zero. You can try initializing turbulent fields as very small (but not zero) numbers. Have you looked at the RANS reactingFoam tutorials (https://github.com/OpenFOAM/OpenFOAM...AS/SandiaD_LTS)? For future reference, it's easier to view the code/error if you attach it with the code tags.
Caelan
Old   January 26, 2019, 22:38
Nikhil Bollimuntha
I'll look into it, and I don't have a RANS reactingFoam tutorial in my tutorials directory, could you please specify which one?
Old   January 26, 2019, 23:12
The link I included is the tutorial. It must have been added for recent OpenFOAM versions.
Caelan
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
