Numerical Instability: decreasing timestep with interFoam |
January 22, 2019, 11:27 |
Hello CFD community,
I am having major stability problems when running a fairly simple case in interFoam. I meshed a pipe connected to a tank using blockMesh. Water should flow through the tube and drop down into the tank that overflows once the water level reaches the outlet. I have kept the space discretization simple. I have tried refining the mesh more but my time step keeps dwindling until it becomes a floating point error. I can barely simulate 0.03 seconds. I would like to know if you have any good tips/strategies for meshing and ensuring the courant number is kept below 1 because up to this point I have basically just been guessing and working through trial and error. I have provided an image of the mesh below as well as the case file which you can find attached as a zip file. You should run blockMesh as I emptied the polymesh file to keep the file size at a bare minimum. Thank you in advance! |
March 23, 2019, 00:35 |
krishna kant
Rep Power: 10 |
I am facing a same problem for solving a swirl jet atomizer. Any help is deeply appreciated. |
NUMERICAL INSTABILITY FOR FLOW OV. SWIRLING VANES | D | FLUENT | 3 | February 9, 2005 16:35 |
NUMERICAL INSTABILITY OVER THE SWIRLING VANES | Dan | Main CFD Forum | 2 | February 9, 2005 09:12 |
Instability of convection | Zeng | Main CFD Forum | 0 | May 26, 2000 06:39 |
New Books and Numerical Software | Eleuterio TORO | Main CFD Forum | 0 | December 18, 1998 13:41 |
Problems of numerical instability because of high gradients | Xiangyang Ye | Main CFD Forum | 4 | September 28, 1998 04:48 |
