Simple heat plate exchanger (chtMultiRegionSimpleFoam)
Old   January 22, 2019, 10:16
Default Simple heat plate exchanger (chtMultiRegionSimpleFoam)
Anders Dyhr Nørløv
MrAndersDk is on a distinguished road
Hello
I've tried to modify the snappyMultiRegionHeater example to make a simple heat plate exchanger. It consist of a side with a flow of cold water, and a side with a flow of hot water, and a thin plate seperating the two sides. (The flow is a cross flow configuration)
The case is setup kinda correct. Understood in the way that the solver starts, however, after a few iterations the temperature blows up, and it fails with errors.
I think that it may be my BC's that are setup wrong, but not sure.
Hopefully someone has time to take a look at my case, and give me some pointers on what could be going wrong?
heatExchanger5.zip
MrAndersDk is offline   Reply With Quote
Ansys Fluent analysis of heat exchanger MStudent FLUENT 2 April 20, 2015 09:40
Plate and tube heat exchanger simulation jatin FLUENT 0 June 16, 2014 05:12
Heat transfer from a heated plate using fins pathakamit FLUENT 1 April 30, 2013 05:07
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
heat transfer on dimpled plate mech FLUENT 4 February 6, 2007 16:15
