AMI and water surface instabilities
Old   January 21, 2019, 21:53
Unhappy AMI and water surface instabilities
Justine
JBrake is on a distinguished road
Hi Again,
I'm creating a new post about the same issue as my last one, but this time I've narrowed it down a bit and am including some new images.
I have a circular (cylindrical) arbitrary mesh interface (AMI) in a mesh that is intersected by a water surface. The solutions start out with some kind of instability that creates very high velocities near the intersection of the AMI and the water surface. I have tried refining the mesh in this area, but the issue persists.
I also see some velocity magnitude around the entire circular AMI region when it should be still:
The results are non-physical and extreme water disturbance, such that I cannot work this the model as it is and greatly need assistance in fixing this issue.
JBrake is offline   Reply With Quote
ami patches, multiphase flow, water surface level
Strange behavior of water surface near solid body JBrake OpenFOAM Running, Solving & CFD 6 January 16, 2019 18:51
Strange behavior--decreasing water level in a hydraulic intake huangxianbei OpenFOAM Running, Solving & CFD 0 October 29, 2017 23:08
Valve Closing of a pipe/moving mesh (for investigating the water hammer effect) silencebreak OpenFOAM Pre-Processing 0 August 11, 2017 14:50
[waves2Foam] waveFoam coupled with AMI sliding interface surfer OpenFOAM Community Contributions 2 November 18, 2014 04:29
AMI simulation unstable within first few timesteps craig0a OpenFOAM Running, Solving & CFD 0 February 24, 2014 13:09
