CentralFoam Temperature Singularity
Old   January 21, 2019, 16:50
Red face CentralFoam Temperature Singularity
Nick Mangione
nmangione is on a distinguished road
Hello. I tried searching for similar problems, but I don't think I can describe this well enough. I am relatively new to CFD, and this is my first OpenFOAM simulation.
I am attempting to simulate supersonic, pressure-driven flow through a curved de Laval nozzle, as is used for isotope separation. Solving with CentralFoam, supersonic flow develops, and then crashes. Looking at the results, there is an area with an impossible set of temperature values, very high and very low right next to each other (see attached picture). There is no shock here, the velocity and pressure fields are smooth and continuous.
Has anyone found this issue before? Otherwise, am I making any obvious errors? (Boundary conditions, choice of solver, etc.)
Thank you for whatever help you can give me!
Pressure, p
    LightOut
        type            zeroGradient;
    HeavyOut
        type            zeroGradient;
    walls
        type            slip;
Temperature, T
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 300;
    LightOut
        type            zeroGradient;
    HeavyOut
        type            zeroGradient;
    walls
        type            slip;
velocity, U
boundaryField
    Inlet
        type            zeroGradient;
    LightOut
        type            zeroGradient;
    HeavyOut
        type            zeroGradient;
    walls
        type            slip;
nmangione is offline   Reply With Quote
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 12:43
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 02:42
Free stream temperature saharesobh FLUENT 1 October 11, 2012 21:52
How to get free stream temperature in boundary condition saharesobh FLUENT 0 October 9, 2012 18:12
