What's the standard unit for forces?
Old   January 21, 2019, 12:11
Default What's the standard unit for forces?
Florian
Archoncomando is on a distinguished road
Hello there,
So i imagine this question will be very silly and easy for some of you but i haven't found a post that helped me here.
So i'm simulating a Wing travelling through water and air at 12.5m/s. Another student is simulating it in x-foil since the professor wants to compare the two.
However his results are around 10kN+ whereas my openfoam log gives me a value of 900 (which i assume is in Newton). That's after 500 timesteps and looking at the values they seem to have converged.
Does anyone have an idea why such a large difference could occur? i've checked the values i input for velocity, densities etc and so far haven't come up with any faults.
I've seen something about forcecoeffs but i can't really wrap my head around what it does.
Any help would be greatly appreciated.
Archoncomando is offline   Reply With Quote
Old   January 22, 2019, 08:36
Zander Meiring
yambanshee is on a distinguished road
I assume you're making use of the forces function in contorlDict? Have you made sure to input your density (rho) here? This is over top of the kinematic viscosity specified in transport properties
yambanshee is offline   Reply With Quote
Old   January 22, 2019, 08:42
Florian
Yes that's the function I'm using. I've got the Rho specified both in the function in controldict and the transport properties etc.
Old   January 23, 2019, 04:09
Bloerb will become famous soon enough
If you are simulating a 2D geometry your forces are still in N. So you need to figure out how deep your mesh is in the third dimension and might have to multiply it by a factor to get the actual force for the entire length of the wing. Aside from that you have to make sure the density is included. Every OpenFOAM input is in SI units. So density in kg/m³ etc.
forceCoeffs calculates the drag and lift coefficient from your forces. It basically devides them by a factor.
Bloerb is offline   Reply With Quote
Old   January 23, 2019, 04:22
Florian
My Mesh is a 3D domain around 10 meters long and 9 meters wide so it's definitely not a 2D Mesh. I'll try around with the coeffs a bit.
Old   January 23, 2019, 06:28
Zander Meiring
You've made sure your reference area is the blade chord*width?
air, forces and force coeff., water, wing
Grid I Unit Normal and Grid J Unit Normal pawansut Tecplot 4 July 31, 2017 19:14
Enthalpies: Am I confused or is OpenFOAM? (rel. standard vs. enthalpy of formation) KarenRei OpenFOAM Running, Solving & CFD 8 November 10, 2016 19:18
how to caculate the mass of impacting particles per unit area and per unit time? xyq916 CFX 0 October 8, 2015 09:55
Boiling simulation ( standard state enthalpy) yasir_hayyat Fluent Multiphase 1 October 13, 2014 04:31
about the unit of the standard state enthalpy!! KEVIN FLUENT 3 March 25, 2004 09:32
