interFoam unable to stabilize the front
Old   January 21, 2019, 08:09
Default interFoam unable to stabilize the front
Max
xneop is on a distinguished road
i am simulating a two phase flow (water, oil) using interFoam. i want to push oil out of the tube. initially oil is full in the tube. At the beginning of the simulation everything is ok, but after some seconds i have a behavior that i do not know how to describe what is happening nor how to solve it. i have attached the results of the simulation in OpenFoam extend 4.0 . Please any Suggestions, links are welcome.
xneop is offline   Reply With Quote
Unable to plot residuals (Interfoam) walakaka OpenFOAM Post-Processing 12 February 9, 2022 06:38
How to make a code parallel? Bruno Machado Fluent UDF and Scheme Programming 15 May 27, 2016 10:18
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
interFoam & decomposition method: scotch MacGyver OpenFOAM Running, Solving & CFD 2 May 23, 2012 08:00
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
