January 21, 2019, 04:59 |
Recyling Method for LES
TongZhou
Hey all!
I recently implemented recycling and rescaling method in OpenFOAM. Based on the boundary condition mappedVelocityFluxFixedValue, I rewrote it to satisfy my research requirements. And I also define a new solver based on pisoFoam. It seems that the code has been programmed in OpenFOAM. Unfortunately, the error was occurred in the process of calculation. [0] #0 Foam::error:rintStack(Foam::Ostream&)[1] #0 Foam::error:rintStack(Foam::Ostream&)[3] #0 Foam::error:rintStack(Foam::Ostream&)[2] #0 Foam::error:rintStack(Foam::Ostream&) at ??:? at ??:? [1] #1 Foam::sigSegv::sigHandler(int)[3] #1 Foam::sigSegv::sigHandler(int) at ??:? at ??:? [2] #1 Foam::sigSegv::sigHandler(int)[0] #1 Foam::sigSegv::sigHandler(int) at ??:? [3] # at ??:? [0] #2 ?2 ? at ??:? [1] #2 ? at ??:? [2] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [3] #3 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/libc.so.6" [2] #3 [1] #3 Foam::List<Foam::Vector<double> >:perator=(Foam::UList<Foam::Vector<double> > const&)Foam::List<Foam::Vector<double> >:perator=(Foam::UList<Foam::Vector<double> > const&)Foam::List<Foam::Vector<double> >:perator=(Foam::UList<Foam::Vector<double> > const&)Foam::List<Foam::Vector<double> >:perator=(Foam::UList<Foam::Vector<double> > const&) at ??:? [0] #4 Foam::scalemappedVelocityFluxFixedValueFvPatchFiel d::updateCoeffs() at ??:? [3] #4 Foam::scalemappedVelocityFluxFixedValueFvPatchFiel d::updateCoeffs() at ??:? [1] #4 Foam::scalemappedVelocityFluxFixedValueFvPatchFiel d::updateCoeffs() at ??:? [2] #4 Foam::scalemappedVelocityFluxFixedValueFvPatchFiel d::updateCoeffs() at ??:? [3] #5 at ??:? [0] #5 at ??:? [1] #5 at ??:? [2] #5 Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&)Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&)Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&)Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<doub le>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? [1] #6 at ??:? [3] #6 at ??:? [0] #6 at ??:? [2] #6 ???? at ??:? [1] #7 at ??:? [2] #7 at ??:? [3] #7 at ??:? [0] #7 ???? at ??:? [1] #8 __libc_start_main at ??:? [2] #8 __libc_start_main at ??:? [0] #8 __libc_start_main at ??:? [3] #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [2] #9 in "/lib/x86_64-linux-gnu/libc.so.6" [1] #9 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #9 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #9 ???? at ??:? Has anyone already faced similar problems in OpenFOAM? Where could this come from? Thank you very much for your time! |
Inaccurate gradient results from continuous Adjoint method | Yminjo | SU2 | 1 | January 11, 2014 23:08 |
multiphaseEulerFoam: method mag(...) withing method solveAlphase() | maybee | OpenFOAM Programming & Development | 0 | December 21, 2013 11:13 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 02:18 |
About flowfield-dependent variation(FDV) method? | Jinwon | Main CFD Forum | 1 | December 4, 2007 22:13 |
tidal flow simulation using finite volume method | Jason Qiu | Main CFD Forum | 0 | October 20, 2002 03:34 |
