Two 2D Cylinders in tandem
Old   January 21, 2019, 03:00
Post Two 2D Cylinders in tandem
Kelvin Xu
Kelvin.xu is on a distinguished road
I am new learner in OpenFOAM.
I've intend to replicate the results based on a reference paper - "OpenFOAM predicitions of hydrodynamics loads on full-scale TLP" for two 2D cylinders in tandem. However, I was unable to achieve the same results or closer to the same results after tried many attempts. Do need helps here!
I have attached my openfoam file and geo format on the model. Due to the limitation of file size that i can upload here. You might need to convert gmshtofoam and amend the boundary in constant file first to run and check.
Question:
1) Am i using the right solver as per reference paper
2) Is my input of parameter correct?
3) Is my Model correctly done? in term of Z or others such as mesh & element?
Greatly appreciated any helps or advise.
Many Thanks.
Regards,
Kelvin
Kelvin.xu is offline   Reply With Quote
Low Re flow past cylinders in tandem ksgr FLUENT 6 April 10, 2016 18:59
Flow around Two Tandem Cylinders Atef FLUENT 3 February 24, 2015 12:35
Problem with geometry - concentric cylinders Rhoddwen OpenFOAM Running, Solving & CFD 0 December 15, 2014 10:22
Flow around two tandem cylinders shantanukale OpenFOAM Running, Solving & CFD 5 May 30, 2014 10:00
heat transfer from 2 cylinders in tandem arrangment noshirvan FLUENT 0 June 29, 2012 05:36
