Increasing the pressure inside the cylinder without compression
Old   January 19, 2019, 09:53
Default Increasing the pressure inside the cylinder without compression
blttkgl is on a distinguished road
Hey,
I want to implement a time-varying pressure field on a piston-like cylindrical domain. I want to match a simple pressure curve I obtained from a similar geometry with specified piston velocity profile wrt time. Specifying the wall movement velocity profile, I am able to move one of the cylinder walls using mesh motion and increase/decrease the pressure based on it. Is it possible to obtain the same pressure curve by explicity changing the value of pressure in each cell during run-time? Will that create a problem (e.g. decoupling of velocity and pressure) during simulation?
I looked at different boundary conditions and one looked like what I need is timeVaryingMappedFixedValue. If I specify all the points in my domain and set them to a fixed pressure value as a function of time would that solve the problem, or am I thinking too straightforward?
Best,
Bulut
blttkgl is offline   Reply With Quote
[snappyHexMesh] Create Cylinder (HOLLOW NO MESH OR CAVITY) inside a Cuboid saddy OpenFOAM Meshing & Mesh Conversion 5 August 8, 2023 08:10
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Flow through small cylinder recirculated inside larger cylinder. Keesie FLUENT 1 July 28, 2016 05:30
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
