chtMultiRegionFoam temperature convergence
Old   January 19, 2019, 09:36
Default chtMultiRegionFoam temperature convergence
Obi
obiscolly50 is on a distinguished road
I'm performing a simple steady-state simulation with one inlet and one outlet using chtMultiRegionFoam. The geometry has a wide aspect ratio with a height of 9ft and width of 200ft. Fluid at a higher temperature of 313K flows in through a 4-inch diameter inlet and leaves through another 4-inch diameter pipe at the outlet. The initial temperature of the domain is 289K and all walls are adiabatic.
The problem I'm having is that after 3000 iterations, the fields don't seem to change anymore which should mean that I've attained convergence, but the solution does not make sense to me. I would expect that the steady-state solution in the case with hot fluid constantly flowing into the domain is a domain with almost uniform temperature of 313K due to mixing and exit of the colder fluid. But from my solution, the heat is concentrated at the inlet part of the domain and the other parts including the exit temperature is still almost 289K.
Can anyone tell me what's wrong or what i could be missing? I believe this could have to do with the length and time scale of my geometry. From my calculation the residence time of fluid in the domain is around 26 hours. How can i quickly approach convergence in this scenario?
obiscolly50 is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Fluid properties as function of Temperature with polynomial using chtMultiRegionFoam qferon OpenFOAM 1 November 3, 2018 14:41
Conjugate Heat Transfer: slow solid temperature convergence Kockaluring OpenFOAM Running, Solving & CFD 7 February 3, 2016 15:03
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Increasing chtMultiRegionFoam Fluid Temperature m.nichols19 OpenFOAM 0 June 28, 2010 16:11
