January 18, 2019, 08:17 |
MPPIC modelling for two different clouds!
Choudhary
Hi all,
I have added MPPIC modelling to coalChemistryFoam. And coalChemistryFOAM works with two different clouds, coalCloud and limestoneCloud. So, I have a doubt regarding if MPPIC considers the interactions between these two different clouds as it considers between the parcels of the same cloud. How the inter-particle stress is calculated in MPPIC library? Does first cloud will have direct interactions with other cloud? Thank You! |
March 28, 2020, 17:55 |
Utkan Caliskan
Rep Power: 12 |
There will be no interaction between clouds as their averaged fields will be completely different. It's not easy to develop an algorithm that considers other clouds in the system. Not to mention, there is a code development standard of OpenFOAM which is, in this case, very challenging to follow.
What is easy is to have different density classes in one MP-PIC cloud. |
cloud, mppic, particle cloud, particle stress, two clouds |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 05:59 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Advice on multi-phase flow modelling | Martin | Main CFD Forum | 3 | October 14, 2008 06:16 |
