Dual-Element Front Wing Case Using SST K-OMEGA |
Jesús Miguel Sánchez
Rep Power: 7 ![]() |
Hello everyone,
I am writting my final thesis on a Dual-Element Front Wing in Ground Effect case. For that, I use SST K-OMEGA with SIMPLE algorithm. The FW (Front Wing) travels at a speed of 13.89 m/s (50 km/h approx.), which gives me a Re number of 524000. The problem is the following. I am trying to solve the boundary layer without the use of wall functions and I don't seem to get any converged results. The residuals do not go any lower than 10^-3 . I have refined several times my mesh untill getting to an average of y+ 1.5- 1.0 approx. I have tried almost everything I have in mind. I do not know if something escapes out of my knowledge scope. To get a better view of the case, I wil describe the grid and the settings. Grid: I use a hybrid mesh that consists of a structural mesh on the wall of the elements of the FW and along the road and of an unstructured mesh around the rest of the domain (Advanced Front Ortho). For the meshing, I use Pointwise. The quality check values I obtained are the following:
Patches:
Set-up: U:
p:
k & omega:
nut:
I do not know if the problem is that I should use a wall function or a low Re wall function. Should I refine below y+ 1? Hope you could help me. Thank you for your time. Best Regards, Jesús Miguel |
openfoam, sst k-omega, sst komega, yplus |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Who know the LANN Wing Case. | boling | Main CFD Forum | 1 | April 19, 2015 07:57 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
how to calculate the omega at inlet boundary in k omega sst | Scabbard | OpenFOAM Running, Solving & CFD | 2 | September 30, 2014 13:06 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
