Problem diverging at different time instants when using hy2Foam with different procs |
January 10, 2019, 02:40 |
TWB
Rep Power: 19 |
I am trying to solve a hypersonic flow past a flat plate problem using hy2Foam, a variant of OpenFOAM meant for hypersonic flow. I'm using the 11 species model and I realise that when I run with 4 and 8 procs, it diverges at around 1e-4 and 5.2e-5 respectively. May I know why this is so? Is this due to the linear solver? How should I troubleshoot? I'm trying to run with 2 procs and see how it goes... |
January 14, 2019, 22:38 |
TWB
Rep Power: 19 |
Hi, I managed to solve the problem myself by using a different linear solver. Changing from PBiCG to PBiCGStab when solving the Yi variables did the trick!
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
