buoyantPimpleFoam setting h in fvOptions (sensible enthalpy)
Old   January 9, 2019, 08:35
Default buoyantPimpleFoam setting h in fvOptions (sensible enthalpy)
Olivier Dambron
olivierdambron is on a distinguished road
hello,
currently working on a free flow convection case in a room using buoyantPimpleFoam solver with radiation. There is an inlet and an outlet all is at ambient temperature 303K with different heat load intesities. I'm interested in verifying that the heat stratification is not excessive.
I am trying to set the heating load of the room using a region of 2 meters high from the ground through fvOptions. For instance 15 W/m3 in that zone.
It seems I can only set h as an injectionRateSuSp. Would anyone know how to calculate it in my case?
heat
type scalarSemiImplicitSource;
active true;
scalarSemiImplicitSourceCoeffs
cellSet heat;
selectionMode cellSet;
volumeMode specific;
injectionRateSuSp
h (10000 0);
olivierdambron is offline   Reply With Quote
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
[swak4Foam] Setting BC for a passive scalar (groovy vs fvOptions) Tobi OpenFOAM Community Contributions 0 May 23, 2013 14:53
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
