Converging Diverging Nozzle with dbnsTurbFoam
Old   January 4, 2019, 02:30
Default Converging Diverging Nozzle with dbnsTurbFoam
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
Hi Foamers,
I used different solvers to estimate the location of the shock wave for the subject case, namely: rhoSimpleFoam, sonicFoam, and rhoCentralFoam using OpenFoam 5.0. However the estimations/results for these solvers were not so accurate comparing to the experimental results.
I am trying to solve the same case using dbnsTurboFoam (density based solver available only in foam-extend 4.0) with no success till now, the value of h is going high very rapidly and floating point exception occurs at the end.
You may find the complete case folder via the below link, you can see that I tried different BC and thermophysicalProperties.
https://1drv.ms/f/s!Amq2JoBgpHbgmRHbcHXEXrg98zaG
Any kind of support will be appreciated.
Thank you in advance.
Saleh
Saleh Abuhanieh is offline   Reply With Quote
Old   January 5, 2019, 10:58
Saleh Abuhanieh
Well .. I know this solver is not so common.. but I am sure many Foamers did it..
Old   December 12, 2019, 15:57
Thomas
hand90 is on a distinguished road
Hi
Were you able to solve the issue? I am using the same solver and encounter similar problems.
Many thanks
hand90 is offline   Reply With Quote
Old   December 13, 2019, 10:54
Saleh Abuhanieh
Hi Thomas,
Unfortunately no.
Regards,
Old   December 13, 2019, 11:26
Thomas
I assume I have a similar issue...The geometry I am modeling is a stator blade with a fixed inlet velocity, fixed inlet temperature and a waveTransmissive outlet. Maybe someone has an idea where the issue could be found. The Mesh seems alright with a non-orthogonality of Max: 45.89 and an average: 16.36.
I first suspected the thermophysical properties but they seem alright to me:
PHP Code:
thermoType
hPsiThermo
<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>;
// name, nMoles, mol weight, CP, Hf, mu, Pr;
mixture         air 1 28.9 1005 0 1.82e-05 0.71
This is the output I get when I run it. This clearly indicates that something goes wrong as the velocity also shoots up to unrealistic numbers.
PHP Code:
Create time
Create mesh
for time 0
Initializing the GGI interpolator between master
/shadow patchesPERIODIC_SS/periodic_sh
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo
Reading field rho
Reading field U
Selecting numericFlux rusanovFluxBarthJespersenLimiter
Creating turbulence model
Selecting turbulence model type laminar
Starting time loop
Courant Number mean
0.15523467 max9.02943 velocity magnitude2
 Time
0.0001
diagonal
:  Solving for rhoInitial residual 0, Final residual 0No Iterations 0
diagonal
:  Solving for rhoUxInitial residual 0, Final residual 0No Iterations 0
diagonal
:  Solving for rhoUyInitial residual 0, Final residual 0No Iterations 0
diagonal
:  Solving for rhoUzInitial residual 0, Final residual 0No Iterations 0
diagonal
:  Solving for rhoEInitial residual 0, Final residual 0No Iterations 0
bounding h
min: -5.4748556e+08 max1.0516812e+09 average322283.12
new min120600
new max804000
bounding rho
min: -0.64592875 max2.5437391 average1.1398913
new min0.10000296
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -7.4175145e+11 max1627402.2 average: -1390944.7
new min120600
new max792543.54
bounding rho
min: -1448.9384 max2550.4832 average1.2205487
new min0.10193838
new max10
bounding p
min5152.4784 max1792217.6 average160869.08
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -7.7758231e+15 max7.7388903e+10 average: -1.820092e+10
new min120600
new max804000
bounding rho
min: -5902750.1 max3308708.2 average: -10.920043
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average230618.34
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -1.0034402e+18 max1.2001047e+15 average: -1.7356107e+12
new min120600
new max804000
bounding rho
min: -1.4206979e+09 max1.2240156e+09 average: -593.21117
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average320947.77
new max1000000
    ExecutionTime
18.41 s
Courant Number mean
22.124283 max95043370 velocity magnitude38063491
 Time
0.0002
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -1.4400817e+21 max7.3840623e+16 average: -2.918162e+15
new min120600
new max804000
bounding rho
min: -5.145617e+08 max3.9814147e+08 average: -729.44621
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average438814.94
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -2.7560433e+27 max1.1947501e+20 average: -2.7284239e+21
new min120600
new max804000
bounding rho
min: -9.6480279e+10 max7.897857e+10 average: -24990.598
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average717589.58
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -8.9519248e+29 max4.9622006e+26 average: -1.199368e+24
new min120600
new max804000
bounding rho
min: -1.77945e+14 max8.2541671e+13 average: -23022481
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average980527.11
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -1.8965922e+34 max1.8479372e+29 average: -3.1049571e+28
new min120600
new max804000
bounding rho
min: -1.053413e+16 max1.3694968e+16 average5.7596284e+09
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1228861.4
new max1000000
    ExecutionTime
30.67 s
Courant Number mean2.9573684e+58 max3.4137433e+64 velocity magnitude1.1977841e+65
 Time
0.0008
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -1.7261537e+136 max3.5040164e+132 average: -1.9902149e+130
new min120600
new max804000
bounding rho
min: -1.6043521e+65 max9.3030893e+64 average: -2.2327806e+58
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1617137.5
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -5.3658521e+140 max3.0051695e+135 average: -9.0106518e+134
new min120600
new max804000
bounding rho
min: -4.8938712e+77 max3.2369183e+77 average: -1.6393966e+71
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1790213
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -4.5691667e+146 max7.9388043e+139 average: -4.5615589e+140
new min120600
new max804000
bounding rho
min: -2.4609042e+70 max1.6069814e+70 average7.3210329e+61
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1786632.7
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -1.8277029e+150 max4.6411647e+145 average: -1.8115129e+144
new min120600
new max804000
bounding rho
min: -7.9445015e+75 max7.8572014e+75 average: -6.2886868e+67
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1786791.7
new max1000000
    ExecutionTime
105.26 s
Courant Number mean
4.0530947e+66 max5.2670735e+74 velocity magnitude3.6185028e+74
 Time
0.0009
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -2.28913e+151 max2.635923e+149 average: -3.2903556e+145
new min120600
new max804000
bounding rho
min: -3.6605447e+76 max5.2267317e+76 average1.5500135e+70
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1626119.9
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -5.3106867e+152 max1.2825681e+150 average: -1.4676302e+147
new min120600
new max804000
bounding rho
min: -1.9967951e+75 max1.1146483e+75 average2.161689e+68
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1787851.8
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -8.9872287e+157 max2.4745995e+152 average: -9.0225504e+151
new min120600
new max804000
bounding rho
min: -2.4311779e+79 max2.5835559e+79 average1.4901175e+72
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1785011.6
new max1000000
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -4.7798214e+160 max1.3470694e+157 average: -4.8954909e+154
new min120600
new max804000
bounding rho
min: -3.5739792e+79 max3.350678e+79 average: -7.7996527e+70
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1787867
new max1000000
    ExecutionTime
117.78 s
Courant Number mean
1.9003026e+72 max2.4619947e+78 velocity magnitude1.2660207e+79
 Time
0.001
diagonal
diagonal
diagonal
diagonal
diagonal
bounding h
min: -1.7871059e+243 max9.4626262e+159 average: -1.7681706e+237
new min120600
new max804000
bounding rho
min: -9.6538203e+80 max1.2541716e+81 average2.9290033e+74
new min0.1
new max10
bounding p
min3452.3917 max2301594.5 average1645121.1
new max1000000
Floating point exception
(core dumped
Fluid Dissociation in Converging Diverging Nozzle Yuqi FLUENT 2 May 29, 2018 12:53
How to determine the distance between points on Converging diverging nozzle geometry Sorwar22 FLUENT 0 December 4, 2017 21:07
Help needed with my Converging diverging nozzle Sorwar22 FLUENT 6 November 8, 2017 18:24
Converging Diverging Nozzle in OpenFOAM danishdude OpenFOAM Running, Solving & CFD 1 September 15, 2012 01:12
help - Running Converging Diverging Nozzle with a shock wave Daco FLUENT 0 September 3, 2012 09:23
