thermophysicalProperties for molWeight and Chemkin file.
Old   January 3, 2019, 02:03
Default thermophysicalProperties for molWeight and Chemkin file.
Andrew Somorjai
massive_turbulence is on a distinguished road
Right now I have the following thermophysicalProperties file
|  \\    /   O peration     | Version:  v1806                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          janaf;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
CHEMKINFile         "<case>/chemkin/chem.inp";
CHEMKINThermoFile   "<case>/chemkin/therm.dat";
CHEMKINTransportFile "<case>/chemkin/transportProperties";
newFormat       yes;
inertSpecie Cs;
Cs
    specie
        nMoles       1;
        molWeight    132.90543;
What I wanted to know is if I needed to declare "inertSpecie Cs;" if I declare it again below that line for Cs. I have my other declaration in a chemkin file but none of them have the molWeight for Cs? I'm not really certain if maybe it should be more like this instead
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
thermoType
    type            heRhoThermo;
    thermo          janaf;
    specie          specie;
newFormat       yes;
Cs
    specie
        nMoles       1;
    transport
    thermo
massive_turbulence is offline   Reply With Quote
chemkin thermo, thermophysicalproperties
CHEMKIN file not understood by OpenFOAM kriete OpenFOAM Programming & Development 3 January 13, 2014 10:00
chemkin file yorelchr FLUENT 0 November 21, 2013 05:52
Help About Chemkin Surface Mechanism file import silverra1n FLUENT 1 October 16, 2013 04:32
Convert CHEMKIN file (.inp or .dat) to .f suffix for AVL FIRE amin_u50 AVL FIRE 3 May 3, 2013 05:00
Question on CHEMKIN INTERFACE Rui Yang Phoenics 7 January 30, 2002 05:04
