How to define setFieldsDict in waveExampleSolitary tutorial in OpenFoam v1806 |
January 1, 2019, 20:05 |
Jiadong Wang
Rep Power: 8 |
Hello Foamers,
I’m working on the waveExampleSolitary tutorial by OpenFoam v1806. But the tutorial crash when I change the mesh. The new mesh is conducted by ICEM. The computational domain is attached. The error message is: Code:
Courant Number mean: 0.00142094 max: 0.666531 Interface Courant Number mean: 0.000296555 max: 0.0831518 deltaT = 0.00152778 Time = 3.37456 PIMPLE: iteration 1 Updating Boussinesq wave model for patch INLET MULES: Solving for alpha.water Phase-1 volume fraction = 0.510157 Min(alpha.water) = -0.000917064 Max(alpha.water) = 1.13209 Updating Boussinesq wave model for patch INLET MULES: Solving for alpha.water Phase-1 volume fraction = 0.510156 Min(alpha.water) = -0.00167893 Max(alpha.water) = 1.13282 Updating Boussinesq wave model for patch INLET MULES: Solving for alpha.water Phase-1 volume fraction = 0.510154 Min(alpha.water) = -0.00231185 Max(alpha.water) = 1.13354 Updating Boussinesq wave model for patch INLET Updating shallowWaterAbsorption wave model for patch OUTLET DICPCG: Solving for p_rgh, Initial residual = 0.00680415, Final residual = 0.00046163, No Iterations 14 time step continuity errors : sum local = 1.32835e-06, global = -2.59204e-08, cumulative = -3.63653e-06 [0] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in /lib/x86_64-linux-gnu/libc.so.6 [0] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? [0] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? [0] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? [0] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? [0] #7 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? [0] #8 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? [0] #9 ? in ~/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/interFoam [0] #10 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 [0] #11 ? in ~/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/bin/interFoam [ryou-virtual-machine:07043] *** Process received signal *** [ryou-virtual-machine:07043] Signal: Floating point exception (8) [ryou-virtual-machine:07043] Signal code: (-6) [ryou-virtual-machine:07043] Failing at address: 0x3e800001b83 [ryou-virtual-machine:07043] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7ff1dceddf20] [ryou-virtual-machine:07043] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7ff1dcedde97] [ryou-virtual-machine:07043] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7ff1dceddf20] [ryou-virtual-machine:07043] [ 3] /home/ryou/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5scaleERNS_5FieldIdEES3_RKNS_9lduMatrixERKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xaf)[0x7ff1de318d7f] [ryou-virtual-machine:07043] [ 4] /home/ryou/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_S9_S9_RNS1_IS8_EESD_h+0xab9)[0x7ff1de31cbf9] [ryou-virtual-machine:07043] [ 5] /home/ryou/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x6f5)[0x7ff1de31ee65] [ryou-virtual-machine:07043] [ 6] /home/ryou/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x187)[0x7ff1e108cf07] [ryou-virtual-machine:07043] [ 7] /home/ryou/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE24solveSegregatedOrCoupledERKNS_10dictionaryE+0x3a8)[0x7ff1e0c28418] [ryou-virtual-machine:07043] [ 8] /home/ryou/OpenFOAM/OpenFOAM-v1806/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x23)[0x7ff1e0bcb6a3] [ryou-virtual-machine:07043] [ 9] interFoam(+0x4c36a)[0x55a72125736a] [ryou-virtual-machine:07043] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7ff1dcec0b97] [ryou-virtual-machine:07043] [11] interFoam(+0x560ea)[0x55a7212610ea] [ryou-virtual-machine:07043] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 0 on node ryou-virtual-machine exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- The setFieldsDict is defined as using the new mesh: Code:
defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (0 0 -0.1513274595) (15 1 0.1513274595); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); Thank you. |
January 14, 2019, 04:19 |
XIANGYU SHI
Rep Power: 9 |
i think u can change CFL <0.5 , could tell me how to plot the first pic. did u uesd paraview?
solitary wave |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
[FSI] HronTurek Tutorial OpenFoam extend: no flag movement | roma-aeterna | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 13 | October 15, 2019 05:11 |
OpenFOAM XiFoam Tutorial FPE Error | Bish | OpenFOAM | 1 | November 15, 2017 18:59 |
Tutorial Not Running In OpenFOAM | H0T_S0UP | OpenFOAM | 2 | January 20, 2015 17:58 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 10:23 |
