Saketh Bharadwaj
Rep Power: 8 ![]() |
Hello, I am using reactingFoam solver for simulating the flow of jet. As no chemical interaction of the fluids(He, N2) exist, I switched off chemistry, reaction and combustion.
When I run the solver I get the following output and an error later. It fails in the first iteration itself and doesnt show any error message. Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 10 corrector loops Creating reaction model Selecting combustion model EDC<psiChemistryCombustion> Selecting chemistry type { chemistrySolver EulerImplicit; chemistryThermo psi; TDAC off; } Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader chemistryModel: Number of species = 3 and reactions = 0 using integrated reaction rate Reading field U Reading/calculating face flux field phi Creating turbulence model. Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon RAS { RASModel kEpsilon; turbulence on; printCoeffs on; Cmu 0.09; C1 1.44; C2 1.92; C3 0; sigmak 1; sigmaEps 1.3; } Creating field dpdt Creating field kinetic energy K No MRF models present No finite volume options present Courant Number mean: 2.69438e-007 max: 0.574089 Starting time loop Courant Number mean: 2.69438e-007 max: 0.574089 Time = 1e-007 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 Generating stack trace... Backtrace: ZN10StackTraceC1Ev [0x705c1465+0x25] module: C:\PROGRA~1\BLUECF~1\ThirdParty-5.x\platforms\mingw_w64GccDPInt32\lib\libstack_tra ce.dll ZN4Foam5error10printStackERNS_7OstreamE [0x11c1c88+0x218] module: C:\PROGRA~1\BLUECF~1\OpenFOAM-5.x\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFO AM.dll ZN4Foam6sigFpe13sigFpeHandlerEi [0x11c2af3+0x33] I dont understand why this happens and what causes this kind of error. Can someone help me with this? |
Radiation Modeling Using Discrete Ordinates Method and Parallel Solver | malicemethods | FLUENT | 3 | May 25, 2018 14:25 |
Modified pimpleFoam solver to MRFPimpleFoam solver | hiuluom | OpenFOAM Programming & Development | 12 | June 14, 2015 21:22 |
pimpleFoam - pisoFoam residuals | RodriguezFatz | OpenFOAM Running, Solving & CFD | 1 | September 25, 2014 08:37 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
