Ümit Yelken
Rep Power: 8 ![]() |
Hi guys, im using chtmultiregionfoam mixed with ddtfoam. When i define the BCs for conjugate heat transfer, im taking error. On the other hand, when i give zerogradient for BCs, it is working well
This is from xieqn.h Code:
#include "compute_sL.H" alphaUnburned = oneKGMS * (-5.47712e-01*pow(fH,8)+1.44848e+00*pow(fH,7)-1.59433e+00*pow(fH,6) +9.49494e-01*pow(fH,5)-3.33735e-01*pow(fH,4)+7.10672e-02*pow(fH,3)-9.01563e-03*pow(fH,2)+5.74169e-04*fH+2.59170e-05); alphaUnburned *= pow(p/pref,0.200); const volScalarField& rhoUnburned = rhou; aUnburned = alphaUnburned / rhoUnburned; aUnburned.max(1e-10); // avoid division by zero in calculation of gCr dimensionedScalar eps0("eps0",dimensionSet(0,2,-3,0,0),1e-9); volScalarField epsilon = max(turbulence.epsilon(),eps0); dimensionedScalar k0("k0",dimensionSet(0,2,-2,0,0),1e-9); volScalarField k = max(turbulence.k(),k0); volScalarField up = uPrimeCoef*sqrt(2.0/3.0*k); up.max(1e-9); volScalarField lInt_Peters = 0.37*pow(up,3)/epsilon; // Peters (CFX) volScalarField b = scalar(1.0) - c; muUnburned = oneKGMS * (-1.08702e-04*pow(fH,2)+1.70856e-04*fH+1.59871e-05); p.max(1.0); // avoid p=0 in the following expression; muUnburned *= pow(p/pref,0.205); muUnburned.max(1e-8); // bounding // quenching: nu = thermo.mu()/rho; gCr = pow(sL,2)/aUnburned; epsilonCr = 15*nu*pow(gCr,2); epsilonCr.max(0.1); // can become zero on BCs volScalarField& lInt = lInt_Peters; volScalarField lKolmogorov = pow(pow(nu,3)/epsilon,0.25); volScalarField sigma = max(0.28*Foam::log(lInt/lKolmogorov), scalar(1e-15)); G = 0.5 * erfc(-pow(2*sigma,-0.5)*(log(epsilonCr/epsilon) + sigma/2.0)); Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib64/libc.so.6" #3 in "/lib64/libm.so.6" #4 Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) at ??:? #5 void Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) at ??:? #6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) at ??:? #7 at ??:? #8 at ??:? #9 __libc_start_main in "/lib64/libc.so.6" #10 at ??:? |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
Defining output as input for second calculation | mannobot | FLUENT | 1 | June 2, 2010 04:20 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
