dynamicMotionSolverFvMesh with topology change |
Sean Gorry
Rep Power: 8 ![]() |
Just wondering if anyone has looked into coupling the ability to handle changing topology and dynamicMotionSolverFvMesh. I have found some documents that discussed combining dynamicMotionSolverFvMesh and dynamicRefineFvMesh. However, I would be interested in using layerAdditionRemoval dynamicMotionSolverFvMesh as I want to use experimental data as an input for pointmotion and then use lAR to remove cells as the fluid domain gets compressed.
Does anyone know if this has been done, or if it is even possible. An possible alternative is to modify movingConeFvMesh but I would have to remove the sinusoidal motion. Any input on this topic would be much appreciated. |
[ICEM] Shifted Periodic topology | venkat_aero2007 | ANSYS Meshing & Geometry | 17 | August 27, 2013 01:41 |
attachDetach Topology Modifier: Proper Turbulent Boundary Conditions | mturcios777 | OpenFOAM Running, Solving & CFD | 4 | September 13, 2012 04:56 |
Topology Change Tutorial | Soheyl | OpenFOAM | 2 | August 7, 2012 19:42 |
Change mesh topology during transient run | Alex77 | CFX | 2 | October 31, 2007 02:35 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
