How to specify a height varying turbulence model variables at inlet |
Rep Power: 8 ![]() |
Fatih Ertinaz
Rep Power: 15 ![]() |
Hello Evren
Did you have a look at the tutorial case "turbineSiting"? It uses ABL settings for U and k-epsilon, so it can be a good basis for your case but you'll probably have to implement sth. like "atmBoundaryLayerInletOmega". If you check "atmBoundaryLayerInletEpsilon" details, I am sure you can figure it out since the core implementation is done at "atmBoundaryLayer" under: Code:
$FOAM_SRC/TurbulenceModels/turbulenceModels/RAS/derivedFvPatchFields Code:
[ertinaz@supernova derivedFvPatchFields]$ ls atmBoundaryLayer -l total 16 -rw-rw-r--. 1 ertinaz ertinaz 4643 Jan 19 2018 atmBoundaryLayer.C -rw-rw-r--. 1 ertinaz ertinaz 7083 Jan 19 2018 atmBoundaryLayer.H // Fatih |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
