December 14, 2018, 07:10 |
Bounding k and Epsilon Exploding
Pedro Amaral
Rep Power: 8 |
Hi Foamers,
i'm quite new on OpenFoam, and i'm having some troubles to run a model with simpleFoam. my simulation runs until 5-15 iterations in average (depending on my relaxation factors) and crashes after that. I'm getting this error message: Error message: Code:
Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.999149, Final residual = 0.0996028, No Iterations 16 smoothSolver: Solving for Uy, Initial residual = 0.999832, Final residual = 0.0874885, No Iterations 17 smoothSolver: Solving for Uz, Initial residual = 0.999298, Final residual = 0.0873607, No Iterations 17 GAMG: Solving for p, Initial residual = 1, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = -nan, cumulative = -nan smoothSolver: Solving for epsilon, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for k, Initial residual = nan, Final residual = nan, No Iterations 1000 ExecutionTime = 685.74 s ClockTime = 744 s [1] [2] [3] [0] [3] [3] --> FOAM FATAL IO ERROR: [3] wrong token type - expected Scalar, found on line 0 the word 'nan' [0] [0] --> FOAM FATAL IO ERROR: [0] wrong token type - expected Scalar, found on line 0 the word 'nan' [0] [0] file: /home/colaborador/Maxzone_v7/processor0/system/data.solverPerformance.p at line [3] [3] file: /home/colaborador/Maxzone_v7/processor3/system/data.solverPerformance.p at line 0. [3] [3] From function 0. [0] [0] From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [0] in file lnInclude/Scalar.C at line 93. [0] FOAM parallel run exiting [0] Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [3] in file lnInclude/Scalar.C at line 93. [3] FOAM parallel run exiting [3] [2] [2] --> FOAM FATAL IO ERROR: [2] wrong token type - expected Scalar, found on line 0 the word 'nan' [2] [2] file: /home/colaborador/Maxzone_v7/processor2/system/data.solverPerformance.p at line 0. [2] [2] From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [2] in file lnInclude/Scalar.C at line 93. [2] FOAM parallel run exiting [2] [1] [1] --> FOAM FATAL IO ERROR: [1] wrong token type - expected Scalar, found on line 0 the word 'nan' [1] [1] file: /home/colaborador/Maxzone_v7/processor1/system/data.solverPerformance.p at line 0. [1] [1] From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [1] in file lnInclude/Scalar.C at line 93. [1] FOAM parallel run exiting [1] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0 with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [KOT81:03349] 3 more processes have sent help message help-mpi-api.txt / mpi-abort [KOT81:03349] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages My boundary conditions are: Velocity: Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.31 0 0); } outlet { type zeroGradient; } upperWall { type fixedValue; value uniform (0 0 0); } lowerWall { type fixedValue; value uniform (2.92 0 0); } frontAndBack { type zeroGradient; } } Pressure: Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } upperWall { type zeroGradient; } lowerWall { type zeroGradient; } frontAndBack { type fixedValue; value uniform 0; } } Code:
Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.995088, Final residual = 0.0958079, No Iterations 13 smoothSolver: Solving for Uy, Initial residual = 0.984021, Final residual = 0.0909928, No Iterations 13 smoothSolver: Solving for Uz, Initial residual = 0.999731, Final residual = 0.0981715, No Iterations 13 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0801382, No Iterations 3 time step continuity errors : sum local = 2.13492e+39, global = -1.70627e+38, cumulative = -1.70627e+38 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.0326797, No Iterations 3 bounding epsilon, min: -6.68363e+72 max: 2.29307e+73 average: 4.19343e+66 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.00813179, No Iterations 1 bounding k, min: -1.94819e+57 max: 3.8381e+59 average: 5.65189e+53 ExecutionTime = 105.32 s ClockTime = 119 s fvSolution: Code:
solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } "(U|k|epsilon|omega|f|v2)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; consistent yes; residualControl { p 1e-2; U 1e-3; "(k|epsilon|omega|f|v2)" 1e-2; } } relaxationFactors { equations { U 0.95; // 0.9 is more stable but 0.95 more convergent ".*" 0.95; // 0.9 is more stable but 0.95 more convergent } } fvSchemes: Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss limitedLinear 1; div(phi,epsilon) bounded Gauss limitedLinear 1; div(phi,omega) bounded Gauss limitedLinear 1; div(phi,v2) bounded Gauss limitedLinear 1; div((nuEff*dev2(T(grad(U))))) Gauss linear; div(nonlinearStress) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } |
December 15, 2018, 22:15 |
Peter Baskovich
Rep Power: 12 |
Hi Pedro,
A few things: 1. Can you share all of your boundary conditions, especially for k and epsilon. 2. What y+ values are you getting? 3. try changing the div schemes for k and eps back to upwind for now. 4. I think your issue is actually with 'p' field, try these URF (under relaxation factor) settings Code:
relaxationFactors { fields { p 0.3; } equations { "U.*" 0.7; k 0.7; epsilon 0.7; } } |
December 17, 2018, 11:03 |
Pedro Amaral
Rep Power: 8 |
Hi Peter,
Thanks for the replying. I've made a few changes in the simulations after i submit this thread and add your suggestions, and it works! Thanks a lot! I've removed the big rectangles from above (image attached), remove the initial velocity from the inlet (let the velocity from lowerwall input the initial velocity) and made your suggestions. For the questions you made: 1) Sure, it's attached right bellow: k Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.000360375; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } upperWall { type kqRWallFunction; value uniform 0.000360375; } lowerWall { type kqRWallFunction; value uniform 0.000360375; } frontAndBack { type zeroGradient; } } Code:
dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.0000138269; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } upperWall { type epsilonWallFunction; value uniform 0.0000138269; } lowerWall { type epsilonWallFunction; value uniform 0.0000138269; } frontAndBack { type zeroGradient; } } U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } upperWall { type fixedValue; value uniform (0 0 0); } lowerWall { type fixedValue; value uniform (2.92 0 0); } frontAndBack { type zeroGradient; } } Pressure Code:
dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } upperWall { type zeroGradient; } lowerWall { type zeroGradient; } frontAndBack { type zeroGradient; } } I'm using this equations to obtain the values of k and epsilon. -------------------------- 2) Y+? I dont get it, what do you mean? (Sorry for the question, i'm really new to OF and CFD in general) -------------------------- 3) Ok! But can you explain why is better run in this schemes? I'm trying to understand the logic behind. -------------------------- 4) Ok! Changed. -------------------------- I'm still getting "time step continuity errors" but i don't understand why/what is this. I set my time step based on my length and initial velocity (l=10m; u=0,31m/s; Delta t = 0,001s). I think if Delta t is really small, this shouldn't been happening, do you know why is this is happening? |
December 1, 2022, 13:26 |
Changed turbulence model
Rasmus Iwersen
Rep Power: 8 |
For anyone that might need a second possible solution:
I had the same issue, epsilon exploding which ultimately lead to expoloding velocities. I've tried updating the mesh several times, although in the end the quality of the mesh wasn't really affected by increasing refinements of surfaces and regions. Truth be told, i didn't try the above suggested solutions, so do try them first. But what i did was to change the turbulence model from k-epsilon to a k-omega SST which uses both k-epsilon and k-omega essentially. Look more into if changing turbulence model might work for you before you do it though. Happy foaming. |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 09:30 |
Bounding k and epsilon & coldEngineFoam | sasanghomi | OpenFOAM | 1 | September 13, 2013 13:12 |
epsilon and K blowing up. | sivakumar | OpenFOAM Running, Solving & CFD | 1 | October 25, 2012 05:50 |
MRFSimpleFOAM goes divergenced! | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 19, 2009 03:11 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 21:21 |
